Thread: POOR RECEPTION
  1. Angry POOR RECEPTION
    banbury,oxon
    Hi everyone i have recently put a PARROT hands free kit in and now the radio reception is awfull.......Has anyone else had this problem when putting orig radio back in, if so how did you overcome it..
    cheers
    lee
    p.s. tried search but can't get it to work??
    Dec 2006
    I believe that the Passat aerial is "active". i.e. it requires a 12v power connection. My new Passat (in 1999) was an import and had no radio fitted. I purchased a radio and fitted it and had rotten reception until I fitted an "in-line" aerial adaptor - picked up 12v from radio connection and reception transformed! Have you disturbed/discarded something to do with this requirement?
    banbury,oxon
    will have a look at that,,,,,,......will let you know how i get on
  4. Talking Re: POOR BAD RADIO RECEPTION PASSAT AERIAL
    Dec 2006
    Hi there
    I followed this thread as I had bad reception on the non vw radio that had been fitted in my passat (2000 1.9tdi estate) by a previous owner.
    I followed 'colesstations' advice about fitting an 'amplified aerial' adaptor which is required by most VWs of this age. It took only 5 minutes to fit and has transformed the reception performance. All you have to do is fit it in line with the aerial plug behind the radio and then there was a lead from my radio that was unused marked pow. ant. which gives it the power. There were also instructions with the lead.
    I purchased the lead from Motorworld for £9.99 was made by 'autoleads' part numbers PC5-90 ISO to DIN or PC5-52 ISO to ISO, or PC5-91 DIN to DIN check what type of connections you require. (Also available from Halfords by £12.99) much cheaper on line just type the part number into google!
    Hope this helps someone else and thanks colestaions
    Dave
  5. Re: POOR RECEPTION
    Aug 2007
    Essex
    My Passat is in for repairs and they have loaned me a brand new Jetta.
    The car is fantastic but poor radio reception.
  1. A4 Symphony II poor reception
    By keysey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2007, 09:51 AM
  2. Bad Reception.
    By Jez. in forum Passat - Archive Topics
    Last Post: 16-03-2007, 03:59 PM
  3. Poor radio reception
    By peterc57 in forum Audi A4 - Archive Topics
    Last Post: 20-01-2007, 11:30 AM
  4. radio reception
    By tony_anon in forum Audi A4 - Archive Topics
    Last Post: 30-11-2006, 01:34 PM
  5. poor reception on Gamma radio
    By mark pountney in forum Chat - Completely Off Topic
    Last Post: 27-05-2006, 07:33 PM
