Thread: How to change the key blade?
  1. Question How to change the key blade?
    Mar 2008
    I've just brought a new remote flip key fob off ebay with a separate blank key blade.
    I've taken the key apart and now I'm left with the old key blade which is connected to the flip mechanism.
    How do i get the old key blade out and the new key blade in?
  2. Re: How to change the key blade?
    Thanet
    If you switch the blade out a bit than you see that it is connected by a small pin. Push that through and the blade comes apart. After you have the new key cut you use the same pin to secure it again in the fob.
    Mind you, you can program the central locking but not the immobiliser! There are plenty threads on this subject though.
  3. Re: How to change the key blade?
    Mar 2008
    I've done that its all good, just went to programe the key but the instructions I got are not working.
    I put the new key in the ignition turnt the car ON and left it in there
    I then locked the drivers door with the second key
    It then told me to press the unlock button on the remote once and the horn will sound once, I done that but nothing happened.
    Some one please help me!!
  4. Re: How to change the key blade?
    Thanet
    this worked for me:
    Programming
    When
    key added or replace
    system malfunction
    How
    NOTE: max of 4 keys can be programmed (one at a time).
    memory positions of existing keys can be identified using diagnostic equipment
    If Diagnostic equipment available:
    locate vacant memory position for new key
    locate memory position for key to be replaced
    carry out programming procedure for this key only
    if diagnostic equipment not available: Obtain and reprogram all keys
    NOTE: Existing key memory positions will be overwritten
    switch ignition ON, Use key not fitted with remote control
    Manually lock driver's door using key.
    Complete the following within 30 seconds:
    Within 5 seconds press unlock button on first key once (programs memory positions 1)
    Indicator lamps flash once to indicate signal received.
    Wait 5 seconds.
    Press unlock button once to confirm programming.
    Vehicle unlocks. Program mode deactivated.
    Switch ignition OFF. Remove Key.
    To program remaining keys into memory positions 2,3 and 4. Carry out the complete procedure below for each key:
    Switch ignition ON. Use the key not fitted with remote control.
    Within 5 seconds press unlock button at 1 second intervals, as follows:
    Twice for memory position 2 (2nd key).
    Three times for memory position 3 (3rd key)
    Four times for memory position 4 (4th key)
    Indicator lamps flash once every time unlock button is pressed to indicate signal is received,
    Wait 5 seconds.
    Press Unlock button once to confirm programming.
    Vehicle unlocks. Programming mode deactivated.
    Switch ignition OFF, Remove key.
    NOTE: Ignition MUST be switched OFF between each key programming procedure.
    Memory erase procedure
    When
    Lost key fitted with remote control
    Incorrect number of keys supplied with vehicle.
    Switch ignition ON.
    Press unlock button 5 times, at one second intervals.
    Indicator Lamp flash once every time unlock button is pressed, to indicate signal is received.
    Wait 6 seconds.
    Press unlock button once (to confirm erase procedure)
    Switch ignition OFF. Remove key from ignition.
    Remote control should no longer operate system.
    Obtain and program all keys.
  1. wiper blade cleaning
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2008, 02:35 PM
  2. A4 Avant Rear Wiper Arm & Blade
    By iawwuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-11-2007, 12:27 PM
  3. 02 Passat wiper blade tips
    By jam in forum Chat - Anything with wheels
    Last Post: 18-06-2007, 01:48 PM
  4. Wiper blade fell off
    By richjthorpe in forum Audi A4 - Archive Topics
    Last Post: 25-01-2007, 11:31 AM
  5. A4 Wiper Blade Arm - Blade Clip
    By lbaters in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-12-2006, 01:16 AM
