Thread: xenon headlights
  1. xenon headlights
    Hi everybody just after some views on the factory fitted xenons. i have them on a 2001 bora tdi sport and am not impressed by them at all does anyone know if there is a way to check the lights are functioning correctly, do the bulbs need replacing every few years? mine do not seem to light up much of the road and i often have to check that they are turned on. but when you look at the car head on they do appear super bright
    How has everyone else found their xenon lghts?
    Thanks in advance for your comments.
  2. Re: xenon headlights
    Feb 2005
    Selby, North Yorkshire
    You should try the standard headlights mate. If you think yours are bad......!
    Even with uprated bulbs they're poor at best.
  3. Re: xenon headlights
    Tyldesley, Manchester, UK
    ^^^Yep the Passat is no better either
    One German, Two Italian.
  4. Re: xenon headlights
    Mar 2007
    Ok i had a problem with my lights... tries brighter bulbs and it did nothing. I took it to an auto-electrician who said there was no problem with them. So i did a bit of DIY work, and simply manually raised the lights with the little screw thing at the top of the cluster. It worked wonders and with some Philips Vision Plus bulbs they're almost as good as any other car :P
    Not sure if this can be done on the Xenons as easily, but it was a breeze on the Halogens.
    08 Jetta TDi
  5. off topic a lot
    Quote Originally Posted by 01V5 View Post
    Just noticed your avatar. I used to own a Honda and still visit the forum occasionally. They would love that avatar not!!!
  1. Xenon Headlights
    By IanT in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2009, 10:20 PM
  2. Xenon headlights for my B6
    By lucas88 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-04-2008, 10:16 PM
  3. Xenon Headlights on new A4
    By Audi Nick in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-03-2008, 06:51 PM
  4. Xenon headlights
    By Heathy in forum Archive posts
    Last Post: 20-12-2007, 01:57 AM
  5. HID Xenon Headlights
    By JoyRider in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-09-2007, 08:09 AM
