Thread: SDi Caddy - HELP PLK
  1. SDi Caddy - HELP PLK
    Sep 2007
    Hi Guys,
    This is a bit of a weirdo problem...
    The van starts but you blip the throttle and nothing - at all.. its still on tickover although it sounds slightly higher than usual.
    (This happened 3 months ago and found some water in an engine bay electrical connection block.. cleared it and then was fine)
    I have re visited the same connector but it seems fine.
    I have also noticed that my VAG Com has stopped working ( is this realtive ) I have checked and the VAG works on our A3..
  2. Re: SDi Caddy - HELP PLK
    london/ UK
    Is that a drive-by-wire engine ? Does it have a accelerator cable between fuel/diesel pump and the pedal ? Can you post a pic of the engine ? If its a drive-by-wire diesel, then there is no phisical conection between the pump and the throttle pedal, there is just a variable resistor built inside the pedal that its known to fail with age. There were people that repaired these but, ussually means a new throttle pedal. Look on ebay as there were a few for sale last week, i would go and get the right part number from the dealer, or buy from Euro Car Parts or GSF a replacement unit. Expect to pay about £80 + VAT...
  1. Caddy key fob
    By DooDah in forum The Commercial Range
    Last Post: 20-03-2008, 07:57 PM
  2. vw caddy styling 04-
    By milesapart in forum Chat - Anything with wheels
    Last Post: 12-02-2008, 02:42 AM
  3. 98 VW Caddy van - fuse box
    By adehardman in forum The Commercial Range
    Last Post: 05-02-2008, 01:29 PM
  4. vw caddy van brakes
    By dazzle93 in forum The Commercial Range
    Last Post: 30-01-2008, 10:23 PM
  5. caddy help
    By golf tdi 02 in forum Polo - Derby - Lupo - Fox
    Last Post: 08-05-2007, 04:24 PM
