Thread: 1997 A4 air con woes...
  1. 1997 A4 air con woes...
    Mar 2008
    My 1997 1.8 se (climate control) seems to have an intermittant problem with the air con.
    That is, sometimes it will turn on, others it wont. When its on it works fine. I can hear the relay click when it does come on, but there is no click when it wont. The little snow symbol just comes on then goes straight off again.
    Any ideas anyone?
    Rich
  2. Re: 1997 A4 air con woes...
    Apr 2007
    Lancashire
    If the outside temperature is below 5 deg C the aircon compressor will not switch on, as it is not needed to regulate temps.
    It may also switch off temporarily under certain conditions if you have an auto gearbox.
  3. Re: 1997 A4 air con woes...
    Mar 2008
    Ah, that explains it. I thought it might have had something to do with the cold, but couldn't understand the intermittant-ness of it.
    Car is a manwel, so can't be to do with an auto box.
    Cheers for that mate
    Rich
  1. abs ecu woes
    By no.10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-10-2007, 06:10 PM
  2. CV Boot Woes
    By taximeistergolf in forum Passat - Archive Topics
    Last Post: 06-08-2007, 07:28 PM
  3. More 80 tdi woes
    By ghee60 in forum 80 - 90
    Last Post: 26-06-2007, 11:38 AM
  4. Climatronic woes
    By SW TDi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-06-2007, 10:48 AM
  5. Alarm woes!
    By quattro2000 in forum Audi A3 - Archive Topics
    Last Post: 26-03-2007, 10:25 PM
