Thread: Changing Camshaft Adjuster Seals without draining engine oil
  1. Changing Camshaft Adjuster Seals without draining engine oil
    State College, PA
    Is this possible? I had this work done at a local dealership, and they said that it was not necessary to drain the engine oil as the work was done on top of the engine. However, the oil that I had seen leaking was apparent from underneath the car. I guess it's possible that the oil was just dripping from the top of the engine and appeared to be coming from the bottom, but I just want to ensure that the mechanic is actually doing the work. I am not familiar with location of the camshaft adjuster seals.
  2. Re: Changing Camshaft Adjuster Seals without draining engine oil
    South Wales
    Not sure what car/engine you have but they do not need to drain the oil on a 1.8t to change the seal/gasket. And the oil leak prob was at the rear of the engine and dripping down to the floor
    It doesnt sound like you were ripped off or anything
    1.8t conversion : SP51x OUTLAW Turbo @ 25psi : Vmaxx Coils : 6 Speed 'Box : GripForce Stg 3 Clutch : S4 Leather : Facelift Console
    Anyone want to swap my A4 for an A3 or similar?? PM me
    243 bhp @ 6415 / 275 torques @ 3370 Chipped UK Rules
  3. Re: Changing Camshaft Adjuster Seals without draining engine oil
    State College, PA
    Thanks for the info! I have a 1999 Audi A4 Quattro - 2.8 V6, and I think you're right. I put the car up on the lift and it looks pretty clean underneath and the oil level is still good. Finally, I may have found a local dealer that isn't filled with untrained monkeys.
  4. Re: Changing Camshaft Adjuster Seals without draining engine oil
    May 2007
    There is no need to drain the oil to change these seals. They tend to be one of the sources of leaks from the engine.
    Have you had the suction jet pump checked, as this is normally the route of the problem.
    When the pump blocks the heads get positive pressure, and leaks appear.
    3 points leak.
    rocker cover gasket.
    cam cover gaskets
    cam shaft oil seals.
    oil either runs down the side of the engine, and leaks on the road, or drips on the exhaust and fills the cabin with the wonderful smell of oil smoke
  1. new cam chain adjuster in 1.8t hard?
    By ssray in forum Chat - Completely Off Topic
    Last Post: 30-06-2009, 09:46 PM
  2. Changing worn transporter TDI engine to Golf engine?
    By flyin-turd in forum The Commercial Range
    Last Post: 18-01-2008, 12:28 AM
  3. Headlight Adjuster - A3 (2000 - X-Reg)
    By paulsmith606 in forum Audi A3 - Archive Topics
    Last Post: 23-12-2007, 01:51 PM
  4. Repair to air vent adjuster
    By braggit13 in forum Archive posts
    Last Post: 02-11-2007, 11:31 PM
  5. Headlamp adjuster stickers on Golf TDi
    By stuart in forum Archive posts
    Last Post: 13-12-2005, 09:47 PM
