Thread: Choke problem, high clutch, fast idle
Results 1 to 10 of 14
Hybrid View
  1. Question Choke problem, high clutch, fast idle
    Mar 2008
    I have a VW Golf 1.8 GTI.
    I've got a problem with the tickover when starting the car up. It revs quite high, then drops down to nearly stooling. I don't know whether the choke is sticking. Its been in the garage and they have replaced a temperature gauge (or something like that) but it doesn't seem to be any better. I have to reverse out of my road and it kangaroos up the road like no-ones business, it is embarrasing. I will then put my foot on the clutch to change gear and the revs shoot up for no reason as I am not putting my foot on the accelorator. Its seems to have a mind of its own.
    The clutch biting point is also extremely high up, despite just having a new clutch fitted. The car is a nightmare to drive because of this. Is there anyway that the biting point can be changed so that it isn't quite as high or it is self adjusting.
    Any ideas what could be wrong with it.
  2. Re: Choke problem, high clutch, fast idle
    134 Post(s)
    2021 Post(s)
    What year and engine code?
  3. Re: Choke problem, high clutch, fast idle
    Mar 2008
    1999. not sure where I can find the engine code but it is a 125 bhp 1.8 20V engine.
  4. Re: Choke problem, high clutch, fast idle
    134 Post(s)
    2021 Post(s)
    The car doesn’t have a choke as such, cold running fuelling and idle control are corrections in the software based on info from engine sensors, such as the coolant temperature sensor which it sound like your garage has replaced. Those engines are prone to dirty throttle bodies which have a motor inside them to control the idle and dirt can cause idle problems, especially after the battery has been disconnected, something you would do when replacing the clutch. A dirty TB is easy for a garage to clean and reset as long as they know how.
    The clutch is hydraulic and self adjusting so I don’t like the sound of that. How much did the clutch cost to do? Do you know if they fitted a new flywheel?
    Your engine code will be AGN.
  5. Re: Choke problem, high clutch, fast idle
    Mar 2008
    Thanks for your help. I think the car will be taking a little trip to the garage now (a different one) to try and get it fixed.
    As for the clutch, can't remember how much it cost as I had the brakes done at the same time. Generally the garage that I go to are pretty reliable and I don't think they would rip me off(??!!) As for the flywheel, not sure they replaced that, I might give them a call to ask. Is it something that a garage would automatically do when changing a clutch?
    One thing I noticed today when I was driving it was that when I put my foot on the clutch, it increased the revs. Is this normal?
  6. Re: Choke problem, high clutch, fast idle
    134 Post(s)
    2021 Post(s)
    The flywheel on the AGN is single mass and doesn’t have to be replaced like on the 1.8T version, I was just interested.
    I don’t quite follow you over the revs going up.
  1. Golf Mk2 Fast Idle When Hot
    By gaddmeg2000 in forum Golf MK2 - 1984 - 1992
    Last Post: 09-09-2012, 02:55 PM
  2. Golf Mk 2 1991 1.8GL Man Fast idle +
    By BrianDunford in forum New Member Introductions
    Last Post: 18-02-2008, 03:22 PM
  3. Fast Idle
    By martlinel in forum Golf MK3 - 1993 - 1999
    Last Post: 14-02-2008, 10:05 PM
  4. Polo 1.4 '97 Fast Idle
    By paddypolo in forum Polo - Derby - Lupo - Fox
    Last Post: 03-12-2007, 12:15 PM
  5. fast idle
    By liambell in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-08-2007, 12:16 PM
