Thread: GT TDI - gear oil spec
  1. GT TDI - gear oil spec
    Mar 2008
    Old Wessex
    I'm looking to change my gear oil to cure cold start problems. I've been recommended Redline MTL; does anyone know the correct spec/viscosity I'll need? Also, does anyone know the standard spec VW use in the factory? I've been searching everywhere for this but can't seem to find out anywhere!
    Any help much appreciated
  2. Re: GT TDI - gear oil spec
    Sep 2007
    yorkshire
    2 LTRS of 75w/90 Synthetic.
    2003 AUDI AVANT SPORT TDI
  3. Re: GT TDI - gear oil spec
    Mar 2008
    Old Wessex
    Thanks a lot, I'll get the Redline stuff in 75/90.
  4. Re: GT TDI - gear oil spec
    you could try just holding the clutch in whilst starting to take the extra drag off the starter motor
    just a thought
  5. Re: GT TDI - gear oil spec
    Mar 2008
    Old Wessex
    Quote Originally Posted by pughster25 View Post
    just a thought
    Thanks anyway but I think you misunderstood what I meant. The problem I'm having is my gear changes are a tad notchy when the engine is cold and was looking to cure this by changing the gear oil. It's my fault for not explaining properly, sorry.
    I was just looking at the Redline range of gear oils and they do a 75/90 GL4 and a 75/90 GL5; does anyone know what the difference is and which one I'll need? Thanks.
  6. Re: GT TDI - gear oil spec
    Sep 2007
    yorkshire
    GL4 http://racing-stuff.com/red_line.htm
    I've read somewhere that gl5 can damage the brass syncros in the gearbox!! Only something I've read mind.
  7. Re: GT TDI - gear oil spec
    Mar 2008
    Old Wessex
    Quote Originally Posted by passat>sport View Post
    Thanks again for your help. After a bit more researching I've found out that what you're saying seems to be true. I'm going to go with the 75/90 GL4, I knew I'd get there sooner or later. Just hoping this stuff is as good as everyone makes it out to be!
  1. RCD 300 on SE spec passat
    By munster71 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-02-2008, 05:53 PM
  2. gt tdi spec and mileage records
    By lfcfivetimes in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2008, 10:17 AM
  3. 'Gutless' new A3 Sportback 2.0 TDI (140) '08 spec
    By GezT in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-08-2007, 02:48 PM
  4. Spec Difference between SE and Sport?
    By Passat130 in forum Passat - Archive Topics
    Last Post: 02-08-2006, 11:14 AM
  5. A4 130 TDi spec
    By Coxy916 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-07-2006, 07:19 PM
