Thread: Most expensive rear door speakers?
Results 1 to 10 of 16
  1. Re: Most expensive rear door speakers?
    Oct 2006
    Sunny slightly hilly Norfolk
    The winders are easy, if you look at them you will see what looks like a spacer between the handle and door. Just push this away from the winder handle (e.g. if the handle is pointed down, the spacer needs to go up) and it will click to allow the handle to come off the splines. It's difficult to explain but once you do it, it makes sense. All VW winders I've come across are like this. Hope this helps!
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  2. Re: Most expensive rear door speakers?
    Oct 2006
    Oh and the radio surround is a pig to get off. I use an ice scraper to lever it away from the dash as it puts pressure over a greater distance on the trim unlike a screwdriver as the trim clips grip very hard. In fact I found one of the clips broke (about £1.25 from the *******) rather than the trim. Oh and you'll need a T20 Torx screwdriver to remove the radio. When you remove it, do it carefully and slowly as you'll need to make sure you get both rubber wedges from the sides, which help locate it in the dash which you can also get from the ******* if you lose 1 (like I did). Helpfully the radio remembers the code when you plug it back in. If you look on www.clubtouran.net there are some pics of this. The following may help if I've done it right http://www.clubtouran.net/forum/showthread.php?t=1565
  1. Mk5 Golf Rear speakers
    By retrodev in forum Golf MK5 - 2004 - 2009
    Last Post: 16-12-2009, 12:59 PM
  2. mrk5 golf rear door speakers?
    By bigsim in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-05-2007, 05:32 PM
  3. 97 avant door speakers?
    By quattro kev in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2007, 08:37 PM
  4. golf plus door speakers
    By rlambert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-04-2007, 12:17 PM
  5. Door Speakers - Help!
    By Maddoggaz in forum 80 - 90
    Last Post: 20-01-2006, 02:19 PM
