Thread: Loud clunking noise from gearbox!!
  1. Loud clunking noise from gearbox!!
    Mar 2007
    Greater Manchester
    This morning I've noticed a loud clunky noise coming from behind me. Could be rear of car or could be centre.
    Symptoms:
    Driving i 1st/2nd/3rd gear the engine/drivetrains make a very loud grinding noise. It's awful. A little down on power.
    When I take my fut off the gas (even for a split second) I get a loud mechanical clunk 'clunk' from the back.
    If i put it in neutral, the engine revs smoothly. And I can let go of the acc without any clunky noises. Only seems to have problem when in gear.
    Awful noise when changing gear... again don't know if this due to letting off the gas or the actual gears grinding. It was a 38 mile trip so I hope I haven't made the situation worse.
    Any ideas?
    The car idles fine. MPG was down but that could be down to climate (-1 degC). I did put in a bottle of Forte Deisel treatment in the weekend but it was alright then.
    2001 Bora TDi PD 115 (AJM)
  2. Re: Loud clunking noise from gearbox!!
    Mar 2007
    Greater Manchester
    Well after an 80 mile round trip of clunking and grinding I took the car to my local garage when I got home.
    He took for a quick test drive... and guessed it was a gearbox/engine mount.
    Got on the ramp, took off part of the belly pan.... a bolt dropped out. It had completely sheared off. You could push the gearbox/engine with your hand and watch it swing. That was making the banging noise.
    Shall have it sorted tomorrow. Hope it's not more than an hours labour!
  3. Re: Loud clunking noise from gearbox!!
    You get this sorted mate?
  4. Re: Loud clunking noise from gearbox!!
    Mar 2008
    concern this problem, as i have the same year and model car.
  5. Re: Loud clunking noise from gearbox!!
    Mar 2007
    Greater Manchester
    Yup... £15 labour and the job's a good'n.
    I asked my brother as he was the last person to drive the car before I noticed the problem... and he did say he heard a loud knock as he went over a speed bump.
    Thankfully there was no excessive damage to other parts.
  1. Clunking noise - offside rear?
    By Heliport in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-12-2016, 12:32 AM
  2. clunking noise from suspension
    By KeithS in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-01-2008, 08:33 PM
  3. A3 2.0t FSI clunking noise
    By thedave18 in forum Audi A3 - Archive Topics
    Last Post: 30-11-2007, 09:08 PM
  4. Clunking Noise when braking at low speed
    By LWW in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2007, 03:34 AM
  5. knocking clunking noise
    By snowdog2005 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2007, 09:18 PM
