Thread: 1988 Gti Golf Loses Power
  1. Unhappy 1988 Gti Golf Loses Power
    Mar 2008
    My wife has an '88 16 valve GTI Golf. Loves it.
    For the past year or so it has begun to intermittently lose power
    while driving. Seems to happen oN the freeway more than in town.
    The only way to restore full power is to turn off the ignition and then
    restart the car ... even if moving.
    I've replaced the main computer with a used one from Pick-n-Pull. No
    change. Has good plugs and recent wires.
    Have any thoughts?
    Thanks & Be Well,
    Gary:
  2. Re: 1988 Gti Golf Loses Power
    Are you sure it’s a problem with the electrics? Could it not be Fuel supply?
    I had a similar problem on an Astra due to iffy fuel pump.
  3. Re: 1988 Gti Golf Loses Power
    Mar 2008
    Hi and thanks for answering,
    Sure it could be the electrics, but you can only trace that when it malfunctions,
    and that's when you're driving. I'd have to get it to a mechanic or the dealership to check for an error with a computer.
    I have thought about the fuel pump also. My experience is that fuel pumps either work or they don't. "Iffy" ... do you think a fuel pump can give "partial and intermittent service"?
    Be Well,
    Gary
  4. Re: 1988 Gti Golf Loses Power
    May 2008
    hi i have an 88 gti 16 valve.
    i have just had the head gasket done and the belt and belt tensioner and i am having simarlar problems with it. When it gets hot, idling in traffic or town driving the engine jumps and cuts out. I looked at the distributer cap and there is a seal gone on there as there is engine oil getting in. The electrics on it are a bit of a nightmare as well. I cleaned the carb as i have been told that they do build up alot of carbon but it doesnt seem to have done much. Any clues?
  1. golf gt tdi (115bhp) 1896 cc, year 1999 Loses Power Occasionally!!
    By karena in forum Golf MK4 - 1999 - 2004
    Last Post: 07-11-2010, 08:02 PM
  2. A3 loses power!
    By manchesta19 in forum Audi A3 - Archive Topics
    Last Post: 20-04-2007, 07:40 AM
  3. 1.4 Twist Loses Power
    By keefb2001 in forum Polo - Derby - Lupo - Fox
    Last Post: 31-03-2007, 03:36 PM
  4. Golf GT TDI - Loses power but motor keep running??
    By buckworld69 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-02-2007, 10:57 PM
  5. Golf TDI loses power at 2500rpm
    By kleky in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-11-2006, 01:18 AM
