Thread: Service On My O2 Polo Tdi
  1. Service On My O2 Polo Tdi
    hI I AM MGOING TO TRY AND HAVE A BASH AT DOING A SERVICE ON MY O2 POLO 1.4 TDI.
    I KNOW I WILL NEED OIL, OIL FILTER, AIR FILTER.
    IS THEY ANY THING ELSE I NEED. AND IS THERE ANY TRICKY BITS.
    I WAS ABLE TO SERVICE MY OLD GOLF GTI BUT IT WAS K REG SO EVERTYTHING WAS SIMPLE TO GET ACCESS TO.
    THESE NEWER CARS ARE TRICKY TO ACCESS AREAS OF THE ENGINE BAY.
    CHEERS
  2. Re: Service On My O2 Polo Tdi
    Chester-le-Street, United Kingdom
    if you have a trolley jack,axle stands, or ramps it shouldn't be too difficult. not sure where the oil filter is, but would look at air filter before you buy one.you may not need it.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Service On My O2 Polo Tdi
    May 2007
    South West
    How many miles has it done? depending on wether you need a fuel filter
    Dan.
  4. Smile Re: Service On My O2 Polo Tdi
    Feb 2007
    Oil changes on the 1.4 TDI are a doddle.No special tools required.Only did an oil change on mine yesterday.
    As long as you can get a container under the sump to drain the oil then it should be a problem.
    Be sure to replace the sump plug and washer....less than £1.50 from main dealer.
    Good luck
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  5. Re: Service On My O2 Polo Tdi
    Quote Originally Posted by djl78 View Post
    Good luck
    dO YOU NEED A TOOL TO UNSCREW THE OIL FILLER AND HOW DO YOU ACCESS THE SUMP PLUG, DO YOU HAVE TO TAKE OF THE PROTECTIVE COVER UNDER NEATH THE CAR?
  6. Smile Re: Service On My O2 Polo Tdi
    Feb 2007
    to re,ove the top of the oil filter bowl you'll need a 36mm socket or a big set of pipe pliers.To get to the sump plug you'll have to remove the splash guard underneath the engine unless you have an oil extractor.
  1. Service reset - 2006 Polo - 1.2
    By RickT in forum Polo - Derby - Lupo - Fox
    Last Post: 17-12-2007, 01:47 AM
  2. polo twist auto service schedule
    By mikcol in forum Polo - Derby - Lupo - Fox
    Last Post: 17-11-2007, 10:50 AM
  3. service reset on polo 53 reg
    By creets in forum Polo - Derby - Lupo - Fox
    Last Post: 30-09-2007, 03:42 PM
  4. My Polo may have missed a service?
    By SGT_Snacks-64 in forum Polo - Derby - Lupo - Fox
    Last Post: 10-06-2007, 07:03 PM
  5. VW polo service costs
    By kiko_VW in forum Polo - Derby - Lupo - Fox
    Last Post: 02-04-2007, 01:53 PM
