Thread: diagnostic port
  1. diagnostic port
    Mar 2008
    hey folks! got a problem with my 1990 20v quattro coupe, theres a sensor packed up. got hold of a diagnostic unit but cannot find the port on the car! anyone any the wiser? cheers!
  2. Re: diagnostic port
    Gwent
    There are 2 or possibly 3 plugs (depending on build date) each plug has 2 pins. If you have an OBD2 connector on your scan tool, you will need a converter lead to connect to the OBD1 type connectors on the car, btw these cars can 'blink' out their fault codes on a LED/low wattage bulb. (if you use a 12v low wattage bulb or 12v led, no resistor is needed).
    more info here
    http://20v.org/tools.htm#VAG1115
    Tools and Parts
    http://20v.org/fault.htm
    The plugs are similar to and in much the same place as this Audi100
    link:http://www.sjmautotechnik.com/troubl...cuf.html#fault
    Audi Technical Information Parts Specialist SJM Autotechnik 503-244-2834 Service Repair
    Diagnostic Fault Codes
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: diagnostic port
    Mar 2008
    cheers man! i will give that a go!
  1. Where is the diagnostic port
    By robb gifford in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2008, 04:02 PM
  2. Diagnostic Port
    By L90OOK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-10-2007, 12:26 PM
  3. Golf Mk5 diagnostic port
    By golftouran in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2007, 07:42 PM
  4. Where is the diagnostic port?
    By RichieVWV6 in forum Passat - Archive Topics
    Last Post: 14-01-2007, 01:18 AM
  5. Audi A6 diagnostic port
    By scibby in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 05-04-2006, 09:27 PM
