Thread: Washer Jets
  1. Washer Jets
    My screen washers seem too low. They hit the bottom of the screen and get masked by the wipers. I looked at them for adjustment but they seem llike a moulded plastic assembly. Is there any adjustment or are they designed into that position?
  2. Re: Washer Jets
    you tried poking some sort of pin into them and see if you can move the bit inside up a bit? worked on my other car...
  3. Smile Re: Washer Jets
    now you have mentioned it the spray on my car is too low as well, i will try the pin trick later but it should do the job!
  4. Re: Washer Jets
    Since I first posted, I've investigated further and there's more to it than that. If you look at the bottom of the jet (against the bulkhead) you will see a screwdriver slot. This is an eccentric cam. Rotating this alters the height and aim of the jet, however I've adjusted mine to aim high and it still hits the arm and sprays low. I think the hole in the jet is a moulding and non adjustable, hence the cam.
  1. Heated washer jets
    By D'Squared in forum Golf MK3 - 1993 - 1999
    Last Post: 07-07-2008, 11:57 AM
  2. Washer jets.
    By Millerman in forum 80 - 90
    Last Post: 25-03-2008, 06:55 AM
  3. Heated Washer Jets for Windscreen
    By Polo Mint in forum Polo - Derby - Lupo - Fox
    Last Post: 21-02-2008, 05:12 PM
  4. Heated washer jets not working.
    By BenR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-12-2007, 11:18 AM
  5. Heated windscreen washer jets?
    By Zub in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:55 PM
