Thread: Wind Noise
Results 1 to 10 of 19
  1. Wind Noise
    I'm getting lots of wind noise around the B pillar, as my seat is quite away from the steering wheel this means the noise is right in my right ear. Has anyone had this problems and if so any suggestions on sorting it?
    "55" 2.0TDi Sport
  2. Re: Wind Noise
    epsom,surrey
    Quote Originally Posted by Astonm View Post
    "55" 2.0TDi Sport
    i also got a lot of outside noise coming in to the interior i have a 55 plate se 2.0tdi. i had a loaner 07 plate and a 57 plate passat 2.0tdi both was quiet. there must be more or better sound proofing i dont know how to find out
  3. Re: Wind Noise
    Chester-le-Street, United Kingdom
    try rubbing some vasaline thickly around door rubbers?
    first time i was up a ladder i was down a well
    4th cog,--two to go
  4. Re: Wind Noise
    epsom,surrey
    Quote Originally Posted by STEWY L View Post
    wot will this do putting vasaline on the seals . has there been a new designed thicker door rubber seals ?
  5. Re: Wind Noise
    Quote Originally Posted by aaman View Post
    only a suggestion to help you find the problem. it works perfectly well on leaking sunroofs,thought it may cut the noise down for you.
    only other thing i can suggest is the dealer
    4th cog,--two to go
  6. Re: Wind Noise
    epsom,surrey
    thanks i will try it
  7. Re: Wind Noise
    perhaps try altering the door latch strikers to pull the door in a bit more?
    4th cog,--two to go
  8. Re: Wind Noise
    What are the door latch strikers and how do you adjust those?
  9. Re: Wind Noise
    open the door and on the pillar you will see either a metal "loop" bolted on with two torqx screws, or a single stud sticking out where the door latch hooks onto when closed.
    loosen these off very slightly and tap them in towards the inside of the car a little. retighten
    and close the door. it should pull the door up on to the seals a bit more.
    4th cog,--two to go
  10. Re: Wind Noise
    I'll give it a go thanks
  1. 1997 1.8 T Sport: WIND NOISE
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2008, 03:49 AM
  2. Post 2005 Polos road and wind noise?
    By highwire in forum Polo - Derby - Lupo - Fox
    Last Post: 08-02-2008, 08:22 PM
  3. Humming/Wind down? Noise When turn off Ignition -
    By BrendanDoyle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2007, 05:10 PM
  4. Golf MK5 Door wind noise and rattles
    By tony444 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-05-2007, 03:28 PM
  5. Wind Noise Problem A3 1998 1.8 20V
    By PARMARZ in forum Audi A3 - Archive Topics
    Last Post: 27-02-2007, 11:40 PM
