Thread: Front Wheel Knocking when turning
Results 1 to 10 of 11
  1. Question Front Wheel Knocking when turning
    Mar 2008
    Just become a member as getting v.frustrated.
    Passat 130tdi (106K)
    When I turn the wheel left or right and apply power, there is a grinding/knocking that seems to be coming from the wheels. It is not there if I coast in/out of gear. I have had it checked to see if anything obvious. No joy.
    Anybody any thoughts please.
    PS I have had the CV boots/joints changed recently as well.
  2. Re: Front Wheel Knocking when turning
    im not a vw guru just yet , but has the passat got inboard cv joints as well as outboard cv joints ??
  3. Re: Front Wheel Knocking when turning
    Mar 2008
    Not sure. I have had a garage look at it and they couldn't find anything. Strange that it is with 'power on,' if I leave the car in neutral and go round the same bend, same speed, no noise. I don't know much about cars hence this thread.
  4. Re: Front Wheel Knocking when turning
    drive shafts wont turn in neutral mate . which suggests to me its a cv joint thats failed. either inboard or outboard.
  5. Re: Front Wheel Knocking when turning
    Chester-le-Street, United Kingdom
    try doing a search for cv joints,thier is lots on them, have heard that thier is something about them that is difficult to line up internally, and if not correct, causes knocking.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  6. Re: Front Wheel Knocking when turning
    Mar 2008
    Mine is the same. I had the cv gaitors changed when i got the car, I was told that it was because the joints had run dry after the gaiters split. The mechanic said it will take a little while for the new grease will take a little while to work it's way in to the joint.
    I was also told to be prepared to pay out for at least on cv gaitor a year because they split regularly on all passat's and audi A4's
  7. Re: Front Wheel Knocking when turning
    "drive shafts wont turn in neutral mate" That would be scary put it into neutral and the drive shafts and therefore the wheels STOP rotating. Regards Peter
  8. Re: Front Wheel Knocking when turning
    Quote Originally Posted by Peter D View Post
    they will spin freely from the gearbox , "wont be under load" so to speak . if that clears it up . .
    its the load from being " driven" that puts pressure on the cv joints.
  9. Re: Front Wheel Knocking when turning
    Dec 2007
    If your gaters split get them replaced as soon as you can , as cv joints with grit and water in them dont last to long after the boots have split, ive learnt from experiance.
  10. Re: Front Wheel Knocking when turning
    But that's what you said. "drive shafts wont turn in neutral mate" Oh yes they will. Regards Peter
  1. Front knocking
    By bonerp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-03-2008, 11:36 PM
  2. clucking noise when turning the wheel
    By roadkill in forum Golf MK4 - 1999 - 2004
    Last Post: 23-02-2008, 11:38 PM
  3. Knocking from front n/s.
    By wid77 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-11-2007, 08:12 PM
  4. Knocking when turning left.
    By forresttc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2007, 12:34 PM
  5. Knocking Wheel
    By The Sloth in forum Golf MK2 - 1984 - 1992
    Last Post: 15-09-2006, 08:34 PM
