Thread: VW Polo 1.9 TDI Problem Petol Diesel Mixed
  1. VW Polo 1.9 TDI Problem Petol Diesel Mixed
    Mar 2008
    My son unfortunately borrowed my wifes car a 1.9 TDI VW Polo 2006. The fuel light came on and he put £5 of petrol in error, realised his mistake and added £10 of Diesel on top believing it would be OK (you wouldn't think he was a university student). He drove around 4 miles and it stalled at a junction. realising his error we then towed it to VW. Anyone know if a 1/3 2/3 Petrol/Diesel mix would have done it significant damage. Please reply if you know.
  2. Re: VW Polo 1.9 TDI Problem Petol Diesel Mixed
    Chester-le-Street, United Kingdom
    don't worry,it'll be fine.you may even have got away with just "brimming"the tank to further dilute it.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: VW Polo 1.9 TDI Problem Petol Diesel Mixed
    Crosby, Liverpool
    Itl be fine, just fill her up with diesel. I filled my MGB with diesel once, it wasnt happy and stopped, drained it, ran petrol straight through the carbs and away it went.Petrol in diesel is harder to sort aswel as it oils up the spark plugs and residue is hard to burn out of the cylinders.Petrol in diesel isnt that much of an issue, as theres no plugs to oil up, just the heat of the compression,it might run like a bag of nails for a bit but it'l sort itself out no probs
    Audi A4 B5 1.6 -1998 <~~~ GONE
    Audi A4 B7 2.0 - 2005<~~~ GONE
    Audi A4 B5 1.8 T 1996 <~~~Here for now
  4. Re: VW Polo 1.9 TDI Problem Petol Diesel Mixed
    Jul 2007
    Cheshire, or my A6
    Aye, just fill it to the top with the black stuff.
    Paul
  5. Re: VW Polo 1.9 TDI Problem Petol Diesel Mixed
    Sep 2007
    that may have been the case in older diesels but not in modern high pressure diesel systems.
    Diesel lubricates the internal parts of high pressure pumps, any contaminant will reduce the lubrication properties and cause potentially high wear rates and rapid failure of internal moving parts.
    In the event of misfueling todays diesel engines, don't start the engine, turn on the ignition or even open the drivers door, any of these actions will/may activate a fuel pump and the whole system is primed with contaminated fuel and an expensive repair bill
  1. Polo 1.9 1998 r-reg diesel
    By andyleggett in forum Polo - Derby - Lupo - Fox
    Last Post: 19-01-2008, 10:29 PM
  2. 1.9 diesel polo - how long will it last?
    By rustygman in forum Polo - Derby - Lupo - Fox
    Last Post: 10-01-2008, 12:57 PM
  3. polo diesel 96, starting probs when hot
    By lanius in forum Polo - Derby - Lupo - Fox
    Last Post: 26-11-2007, 11:15 PM
  4. A4 quattro - mixed tyres
    By dav1000 in forum New Member Introductions
    Last Post: 17-02-2007, 11:26 AM
  5. A4 quattro - mixed tyres
    By dav1000 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-02-2007, 04:34 PM
