Thread: Lights warning buzzer doesn't work..HELP!
  1. Lights warning buzzer doesn't work..HELP!
    sharastani Guest
    Could this just be a new fuse required...if so any idea how I identify the fuse on the fuse card...
    It doesn't seem obvious by the pictures........
    Oct 2006
    I think that it could be the switching unit in the keylock on the door that is going/gone.
    My 99 Bora is suffering the same problem, but has progressed a little since.
    1)Buzzer doesn't sound when the lights are left on.
    2)The interior lights don't come on when the drivers door is opened. Whereas if I open the Passagner door they do come on.
    3)If I unlock the car from the passanger side using the key the interior lights come on, don't do so from the drivers.
    4) Now the latch on the drivers door is acting up, some thimes i have to slam it 2 0r 3 times to close it.
    All this leads me to think that the lock and swithch are a combined unit, I read on one of there forums that the switch is quite tricky to replace, an involves removing door trim for a start.
    Let me know how you get on, I won't be fixing mine before the new year.
    Richard.
    london/ UK
    Yes, get a workshop/repair manual as the microswitch in the lock might be faulty. The solder joints often break and will give the mentioned symptoms !
    Oct 2005
    Lutterworth
    This is for a Passat but the Golf will be similar: http://www.taligentx.com/passat/main...lockmechanism/
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  1. POLO - Anyone ever change "lights on" buzzer unit??
    By premierGunner in forum Polo - Derby - Lupo - Fox
    Last Post: 31-03-2009, 12:01 PM
  2. Interior Lights dont work
    By GrahamO in forum Chat - Completely Off Topic
    Last Post: 23-02-2007, 11:45 PM
  3. esp/abs warning lights
    By craig1 in forum Audi A4 - Archive Topics
    Last Post: 29-01-2007, 02:04 PM
  4. Light/Petrol Warning Buzzer
    By scisuk in forum Audi A3 - Archive Topics
    Last Post: 02-01-2007, 10:26 AM
  5. Lights left on warning buzzer not working - fuse??
    By sharastani in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-12-2006, 12:28 PM
