Thread: Passat CV Boot replacement
  1. Passat CV Boot replacement
    Jun 2007
    Rugby, Warwickshire
    Hi All,
    I need to replace the outer cv boots on my 03 Passat Estate, and have just been quoted £212 +vat for doing both sides by a local VW service specialist (not a dealer). Does this sound about right or over the top?
    Are they an easy DIY job as I don't have a garage and it's starting to get damp outside!
    I have also looked at the 'split cv boot' kits - any views on these?
  2. Re: Passat CV Boot replacement
    london/ UK
    Thats a lot of money...If you come to London, i could do them for 100 pounds including the parts ! It will take about 1.5- 2 hours ! They are ok to replace if you are a good DIY mechanic, but you will need a set off basic tools, a long breaker bar and a pair of axle stands and a few more basic tools(snips, pincers, balljoint separator,large hammer, big flat screwdriver, etc.) and a good workshop manual like Haynes ! Take your time and you wont go wrong. There is a how to in one off me old treads, if you decide to DIY , just read it and take care when you split the CV joint to put the washers/springs the right way round. Regards, Chris.
  3. Re: Passat CV Boot replacement
    Sep 2007
    North Wales
    That price is a bit steep, I had mine done as well as a service and brake fluid change, at a VW main dealer for £224.
    In my experience, all be it not on VW's, the split boots are allright for a quick repair to get you through an MOT, but don't last.
    Steve. 2002 (52) Passat 1.9 TDi 130bhp (AWX)
  4. Re: Passat CV Boot replacement
    Dec 2005
    Quote Originally Posted by adamss24 View Post
    Hi
    I am looking for a guide to replace my outer cv boot on a 98 passat 1.8t petrol. I have trawled threw adamms24 previous replies to find the HOW TOO but can't find it. I would be gratefull if anyone could point me in the direction of the 'How Too' cv boot replacement.
  5. Re: Passat CV Boot replacement
    Jan 2008
    Solihull
    There's a useful guide here...
    http://www.taligentx.com/passat/maintenance/cvjoints/
    Use it along with the Haynes manual,although when the Haynes manual tells you to screw the driveshaft bolt into the end of the CV to separate it from the shaft....IGNORE IT! All that does is knacker the end of the bolt, so you can't unscrew it. Don't ask me how I know.
    The other thing I discovered - on my 53 plate 1.9 TDI - is that you don't need to undo the steering/suspension joints. By unbolting the inner CV joint from the gearbox and then jacking the suspension upwards, the inner end of the driveshaft drops low enough to clear the gearbox.
    I have now done both sides and the offside was much easier.
  6. Re: Passat CV Boot replacement
    Dec 2005
    Thanks for the info but where is adamms24s' guide?? It's just bugging me that it can't be found.
  7. Re: Passat CV Boot replacement
    Duffield, Derby
    Quote Originally Posted by capolla View Post
    Check my postings in this thread. I've also posted a how to link in there as well.
    http://www.ukpassats.co.uk/phpbb/vie...php?f=8&t=5963
  1. new passat boot opens!
    By michaeldonnelly in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-10-2008, 07:52 PM
  2. Water ingress into VW Passat Boot
    By peter.james in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-08-2007, 07:21 AM
  3. Driveshaft boot replacement
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-05-2007, 05:50 PM
  4. Passat cannot open boot
    By passman in forum Passat - Archive Topics
    Last Post: 26-03-2007, 08:44 PM
  5. Passat Boot Leak
    By 4motions in forum Passat - Archive Topics
    Last Post: 21-03-2007, 03:07 PM
