Thread: 02 Passat Xenon Headlights
  1. 02 Passat Xenon Headlights
    Hi all,
    I have a 02 passat tdi sport 130. One of the headlights has started acting up. When you turn the switch, it might not come on and if it does it will flicker and then stay on.
    Sometimes the lights don't auto level when turned on first thing and the light doesn't seem to get to the same level of whiteness as the other one.
    Anybody any advice on whats broken? Any idea of repair cost?
    C.
  2. Re: 02 Passat Xenon Headlights
    Jun 2006
    UK, Mids
    Sounds like the ballast or lamp capsule. You can get cheap D2S capsules on ebay and if the problem still exists, it's probably the ballast. You could alternatively swap left to right and vice-versa to see if the fault moves with the part. As for the auto-levelling, best to get the fault codes read.
    Audi A8 - 2015 - 3.0TDI
  3. Re: 02 Passat Xenon Headlights
    By any chance, does anyone know what type of ballast i need for my xenon headlights?
    apparently there are a heap of different types (a whole range of H numbers).
    I've had all the capsules replaced and the drivers light is still problematic for turning on.
    Can anybody tell me where to look for the correct ballast?
    Conor
  1. Passat B5 Xenon Headlights
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2010, 01:51 AM
  2. Xenon Headlights
    By IanT in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2009, 10:20 PM
  3. 2005 Passat With Bi-Xenon Headlights
    By Mark Hutchinson in forum Passat - Archive Topics
    Last Post: 05-01-2008, 09:58 AM
  4. Xenon headlights
    By Heathy in forum Archive posts
    Last Post: 20-12-2007, 01:57 AM
  5. HID Xenon Headlights
    By JoyRider in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-09-2007, 08:09 AM
