Thread: accelerator pedal position sensor
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: accelerator pedal position sensor
    131 Post(s)
    1976 Post(s)
    Dynamic pump timing, has the timing belt been changed recently?
  2. Re: accelerator pedal position sensor
    hi iwas thinking of having it changed as the service book does not indicate if it has been changed the 2nd time it has covered 130,000 miles so i think i need to change it what else would i need to change with it i.e water pump, tensioners e.t.c and how much will it cost thanks
  3. Re: accelerator pedal position sensor
    131 Post(s)
    1976 Post(s)
    You need a full timing belt kit (belt, tensioner, relay roller and required fastenings) 028 198 119 C at £76.38 from Audi. I have started using genuine kits due to the two year labour inclusive warranty, peace of mind for me and the customer. The water pump is external and separate on yours so isn’t required at the belt change. The labour for this job is about four hours so typically around £200. Ask about the pump dynamic timing, what is called the “Commencement Of Injection” or COI. This is done using the diagnostic computer in Basic Settings 04, group 000 and is not done with the locking tools. Quiz the prospective garage about this and judge for yourself whether they know how to do this. It is done with the engine running and by moving the pump or on cars with a two piece pump sprocket, laboriously starting and stopping the engine to make adjustments.
  4. Re: accelerator pedal position sensor
    thanks for the info
  1. Warning, accelerator pedal stuck !
    By carl s in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-01-2009, 03:34 PM
  2. Accelerator Pedal
    By nicky900 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-12-2008, 09:03 PM
  3. Accelerator Pedal
    By JoGibson in forum Golf MK4 - 1999 - 2004
    Last Post: 19-10-2008, 03:16 PM
  4. Accelerator pedal
    By Cossie 2.5 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2007, 12:32 PM
  5. Strange Tapping on Accelerator Pedal....
    By topgazza in forum Polo - Derby - Lupo - Fox
    Last Post: 05-07-2007, 09:01 PM
