Thread: accelerator pedal position sensor
Results 1 to 10 of 14
  1. accelerator pedal position sensor
    hi to all my first post so give me time please i have an audi a4 tdi 1998 110 bhp basically it does not go over 80 mph on the motorway and struggles uphill had the diagnostics done error code 0226 which i was told is the accelerator pedal position sensor. problem is dealer wants £275 part number 028907475b i have found one with part number 028907475aj of a passat is there any difference thanks
  2. Re: accelerator pedal position sensor
    Mar 2008
    we got same problem audi a4 1.9tdi
    can anyone tell me where its located and if a passat one will fit
  3. Re: accelerator pedal position sensor
    131 Post(s)
    1974 Post(s)
    In one year they used three different pedal sensors.
    028 907 475 B up to chassis wauzzz8DzW (A or I) 028 000
    028 907 475 S from wauzzz8DzW (A or I) 028 001 to wauzzz8DzW (A or I) 080 000
    028 907 475 AJ from wauzzz8DzW (A or I) 080 000 onwards
    And that is for manual boxes models, there are two more for auto.
    The sensors are not interchangeable.
    They are located on the pedal box under the dash
    The Passat 3B for 98 used the same part numbers.
  4. Re: accelerator pedal position sensor
    Mar 2008
    thanks bud
    any idea how much they cost
    96 1.9 tdi auto
    is the above correct
    thanks
  5. Re: accelerator pedal position sensor
    hi i have purchased one from a breaker for £47 inc v.a.t
    will try it out and see what difference it makes will let you know how i got on
  6. Re: accelerator pedal position sensor
    131 Post(s)
    1974 Post(s)
    You need sender part number 028 907 475 C which costs £336.05 inc. VAT. It was only used on TDI Auto’s around 95 to 97 but was used on the A6 TDI and Golf, Saharan and Passat TDI auto
  7. Re: accelerator pedal position sensor
    Mar 2008
    thanks he will be pleased lol
  8. Re: accelerator pedal position sensor
    Mar 2008
    Quote Originally Posted by 4udi View Post
    how did you get on with new part any better
  9. Re: accelerator pedal position sensor
    sorry for l8 reply just got car back yesterday anyway the ride was more smoother (still need to check it uphill) on the motorway seemed okay but could not really test it as m6 j5 to j9 is terrible in traffic terms but a new fault code has appeared 00550 something to do with Start of injection regulation can someone tell me why this has come up now and not before and does it concern the boost problem thanks
  10. Re: accelerator pedal position sensor
    back again seems like it did not sort the boost problem out although it is much smoother fault code has gone and a new one popped up 00550 where was it before and why???
  1. Warning, accelerator pedal stuck !
    By carl s in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-01-2009, 03:34 PM
  2. Accelerator Pedal
    By nicky900 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-12-2008, 09:03 PM
  3. Accelerator Pedal
    By JoGibson in forum Golf MK4 - 1999 - 2004
    Last Post: 19-10-2008, 03:16 PM
  4. Accelerator pedal
    By Cossie 2.5 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2007, 12:32 PM
  5. Strange Tapping on Accelerator Pedal....
    By topgazza in forum Polo - Derby - Lupo - Fox
    Last Post: 05-07-2007, 09:01 PM
