Thread: Correct antifreeze
  1. Correct antifreeze
    I've not had my Audi A6 1.9 TDI 130(PD) for long so I'm going to drain the cooling system and replace the antifreeze as I don't no how much if any is in there. Do I have to use the VW antifreeze are will any good quality stuf do thats made for alum. engines.
    Is there any special filling or bleeding technecs neaded.
  2. Re: Correct antifreeze
    Mar 2008
    If the coolant in the header tank looks clean and pink in colour and not scummy I wouldnt bother. Sometimes draining coolant can result in airlocks and all kind of subsequent problems like heaters not working and boiling over and overheating engines with the possiblity of seizures. There is a well known saying "Leave well enough alone". This is especially relevant when it comes to tinkering with cars
  3. Re: Correct antifreeze
    Mar 2007
    Yorkshire
    Quote Originally Posted by chat View Post
    Another phrase which equally comes to mind is, "If it aint broke, don't fix it."
    You can get antifreeze testers in motor factors for less than it will cost you to change the antifreeze.
    2007 Audi A6 3.0 TDi quattro S line manual saloon
    1975 Rover P6 4000S 5 speed
    Time flies like an arrow
    Fruit flies like a banana
  4. Re: Correct antifreeze
    Chester-le-Street, United Kingdom
    Quote Originally Posted by buster View Post
    dip your finger in the header,or expansion tank and just touch it on the tip of your tongue. if it's sweet to the taste,forget about it.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  5. Re: Correct antifreeze
    Thanks for that I'll give that test with dipping the finger in a try as I checked it with an antifreeze tester and it looked border line for being protected maybe I'll drain a little bit off and put in a litre of the proper VW stuff.
  6. Re: Correct antifreeze
    Mar 2007
    Yorkshire
    Quote Originally Posted by lufftube View Post
    If you mix the G12 anti-freeze with other makes, it will go brown and bitty, as if it had gone rusty.
    Just to be on the safe side, add just a little of the proper anti-freeze to the litre of coolant you drain off and check its ok.
  1. a6 2.6 running temp +antifreeze
    By jimmpad in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-04-2009, 09:02 AM
  2. Correct Oil
    By kasbridge in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-04-2008, 04:24 PM
  3. is this the correct thermostat? how to test it?
    By shagi101 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-02-2008, 11:59 PM
  4. non G12 coolant/antifreeze used - advice please
    By Tman08 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-01-2008, 02:32 PM
  5. Passat TDi antifreeze
    By warrtydog in forum Passat - Archive Topics
    Last Post: 22-01-2008, 12:27 PM
