Thread: installation of mmi sat nav a6
  1. installation of mmi sat nav a6
    Mar 2008
    hi there new to the forum and just picked up my a6 s line today new shape 2005 and its great but i would like to get the sat nav installed any type it has the button it has the colour screen. but nothing else. can any one help please even if its alink to previous post. thanks i advance . brian
  2. Re: installation of mmi sat nav a6
    May 2007
    knee deep in clunge
    14 Post(s)
    Yes you can retrofit sat nav to mmi high and it takes about 2 hours.Audi parts supply the kit with the instructions,you will require vag com 704 to code gateway and encode the sat nav or fit it and ask the dealer to set it up also depending on your sw version of the mmi 2020 and above you should get tmc function also.http://www.kufatec.de/shop/product_i...lus-A6-4F.htmlVag com code 19(gateway) select nav click to codeinto gateway for installation.Then out of 19 and select 37 nav and select adaption channel 01 and enter the tyre diameter ie 206/60r16 =1 990mm then select channel 2 and enter the pulse value of 96 and save.Clear all fault memory and turn ignition off/on and away you go
  3. Re: installation of mmi sat nav a6
    Belfast
    Cost?
  1. avl installation
    By Jorge in forum Touareg
    Last Post: 05-01-2008, 12:18 AM
  2. Mfd installation!!!
    By GTTDI180 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2007, 09:43 PM
  3. Naviplus RNS-E installation
    By Bossy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-10-2007, 03:34 AM
  4. cd changer installation
    By swannie20 in forum Archive posts
    Last Post: 06-12-2006, 11:00 AM
