Thread: 1992 jetta, No Spark??
  1. 1992 jetta, No Spark??
    Mar 2008
    I have a 1992 Jetta, 1.8, manual transmission, that will turn over, but wont start. I have fuel, no spark. I have power at the Hall sensor. How do I check to see if the coil is getting power? Thanks in advance.
  2. Re: 1992 jetta, No Spark??
    Mar 2007
    coventry
    disconnect the coil lead and leave attatched on the body if there is a spark then the coil works
    let us know how it goes ???
    no matter how you try you always come back to what you first started
  3. Re: 1992 jetta, No Spark??
    Mar 2008
    Quote Originally Posted by golf tdi 02 View Post
    No luck, no spark there.
  4. Re: 1992 jetta, No Spark??
    Mar 2007
    coventry
    sorry disconnect the coil lead from the dizzy cap then rest on body and see if sparks if not you need new coil
  5. Re: 1992 jetta, No Spark??
    you should get +12v on the +15 side of the coil,black wire i think,if no power to coil there wont be a spark
  1. 1992 Jetta central locking sysetem
    By westag in forum Jetta MK2 - 1984 - 1992
    Last Post: 11-10-2008, 08:36 PM
  2. 1996 Jetta no spark
    By jpinto101 in forum New Member Introductions
    Last Post: 07-04-2008, 05:11 PM
  3. lol! did just about everytyhing, and 94 2.0L Jetta STILL NO SPARK!
    By sinanovicha in forum Vento - 1994 - 1998
    Last Post: 13-12-2007, 08:33 PM
  4. big problem ! 1994 2.0 jetta NO SPARK plz HELP
    Last Post: 06-12-2007, 01:53 AM
  5. mk3 1992 gti 8v running rought need help
    By cr4igo in forum Golf MK3 - 1993 - 1999
    Last Post: 03-12-2007, 10:12 PM
