Every now & again the steering goes very heavy for a few seconds when making a tight turn. On checking over a pit with car jacked up & engine running & 1st gear engaged diff sounds like a bag of hammers ! Took oil sample but found absolutly no debris. Decided to continue use & see what developed. After 9 months absolutly no change.
However I am now getting severe squealing noise from PAS pump & heavy judder from steering wheel when on full lock, both directions (PAS pump belt is new & correctly tensioned) Before I "invest" in a new rack / pump does anyone have experience of simillar behaviour. I suspect the rack is on the way out but maybe it could be the pump ??
