Thread: Juddering clutch om my transporter
Results 1 to 9 of 9
  1. Juddering clutch om my transporter
    Mar 2008
    Hi my T4 van is suffering from a juddering noise from the clutch as you take off only bought the van monday from a dealer went back today and said to him and he told me that all vws do it its because its a five cyclinder has any one self had same problem
  2. Re: Juddering clutch om my transporter
    Mar 2008
    Sounds to me like either oil on the clutch plate or knackered clutch plate springs. I can't believe all VWs do it, or nobody would buy one.
  3. Re: Juddering clutch om my transporter
    Mar 2008
    Hi thanks for reply is it much work to do this job as im gonna take it back tomorrow and say to him that im not happy with it .Is it much work to fit new clutches in these vans cause i havent got a clue
  4. Re: Juddering clutch om my transporter
    Mar 2008
    Although I've never done a clutch in a T4, I can't imagine it's any more difficult than any other clutch. Probably no more than a couple of hours work for an experienced mechanic.
  5. Re: Juddering clutch om my transporter
    Mar 2008
    Thanx for yr advice yr opinion is much appriated some one said it might cost as much as £1200 i nearly fell over
  6. Re: Juddering clutch om my transporter
    May 2008
    Hi!
    You have got a worn clutch all right. Your salesman is pulling you leg. I had my clutch changed here in Norway for 2 years ago. Cost 1500 £. (Everything is expensive here..)
    Not a good idea trying to change it yourself- I have heard it's a specialist job
  7. Re: Juddering clutch om my transporter
    Jun 2008
    I had this problem on my T4 2.4 5 cylinder at around 200,000 miles especially in reverse uphill. I traded it in for a 2.5tdi after it had reached 250,000 miles still with the same worn out clutch ,never slipped once.
    I would change a clutch on this van myself and it should cost me no more than £150.for parts and all the pain killers I am allowed by my nurse.
  8. Re: Juddering clutch om my transporter
    dirtdigger Guest
    Judder is a common problem with T4s. It may be ok, but could be on its last legs? Its a major job to change, engine out (through the bottom) complete with gearbox and suspension, on 2.5s, not really a diy job?, about £700ish by VW I gather.
  9. Re: Juddering clutch om my transporter
    Feb 2007
    If the judder is caused by a Dual Mass Flywheel (DMF) starting to fail that will add to the expense. AFAIK these were mostly fitted to the 4 cyl engines, not the 5 cyls.
    My T5 5cyl manual has no clutch judder at all. The engine has a slightly uneven throb due to it being 5 cyl, but you couldn't call it a "judder".
  1. clutch juddering on biting point....
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2009, 10:50 PM
  2. Audi A6 2.0 TDi 2005 'juddering' clutch
    By Mark Carter in forum Chat - Completely Off Topic
    Last Post: 12-01-2009, 11:05 PM
  3. Do I need a new clutch on VW Transporter ?
    By Mayo in forum Archive posts
    Last Post: 03-01-2008, 08:18 PM
  4. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
  5. Juddering C
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 06:00 PM
