Thread: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
Results 1 to 10 of 10
  1. Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2008
    Im fairly new to this site but thought someone may be able to help me. I have a 150 BHP GTTDI golf (2003), recently my clutch seems to be acting up on occassions. The clutch seems to slip in the higher gears after 4th gear at above 2000 rpm where the revs go up suddenly cos i assume the clutch is slipping and then come back down to normal. This happens when i put my foot down slightly. Also I have when i come off the motorway after about an hours drive the clutch pedal goes really soft with no resistance till the very bottom which makes it very difficult to change gear (biting point goes lower) temporarily for a few mins straight off the motorway after whcih the clutch returns to normal. These problems have got me worried as to what the cause may be? Does this mean i need a new clutch how can i find out? Also how much would it cost for a new clutch parts and labout assuming it is a new clutch i need?
    Would really appreciate any help/advice as its driving me up the wall!
    Rio
  2. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2008
    Leiderdorp, Netherlands
    Hi I had a similar problem on my Polo, and the bad news is that if it is the same problem you will need to change the clutch and sooner rather than later. The problem that I had was that the thrust started to eat its way through the pressure plate.
  3. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2008
    Is there a to test whether its the clutch? any idea on cost?
    thanks
  4. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2007
    coventry
    sorry for the bad news but you have a dmf dual mass flywheel and very expensive if you go to the main *******.
    i think the last quote i had was around the 295 price
    do change the flywheel at the same time as you do not want to do the same jobs just months apart.
    try euro car parts your local branch or german and sweedish both very good for prices and quality parts...
    hope this helps ...rich...
    no matter how you try you always come back to what you first started
  5. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2008
    Looks like my spending money is going to be blown! pardon my ignorance but what is a dual mass flywheel?! is this part of the clutch or separate? the 295 figure you said is that just for the dmf? Also any idea on labour cost is it a difficult job?! Thanks for the advice
  6. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2007
    coventry
    ok sorry bit late at nite
    the 295 consists of
    1x friction plate
    1x release bearing
    1x pressure plate
    1x dual mass flywheel
    the above price is just for parts labour is around 150 250 local garage
    as for hard have you changed a clutch before ???
    very inportant to align correctly
    as said the dmf is a new version of the fly wheel as to take the lash off the gear box as vw.s havw allways had g. box probs
    hope this helps ...rich//
  7. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2008
    Rich thanks for your help. Im quite an amateur with cars to be honest but learning slowly! have a haynes manual here so will read up on what makes up the clutch etc. I assume the parts you have suggested make up the clutch?! really appreciate your help cos to be honest i dont have a clue apart from noticing that my clutch is slipping! hence thinking its a problem with the clutch!
  8. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2007
    coventry
    wipkedea the dmf and have a look ??
  9. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2008
    I may just do that will make some good bedtime reading though the mrs wont be impressed!!! lol!
  10. Re: Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    Mar 2007
    coventry
    mine has just got the hint to go to bed
  1. Golf MK5 TDi 1.9 Clutch Problem
    By db1145 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-02-2008, 09:11 AM
  2. MK5 Golf Clutch Problem
    By brentos2004 in forum Golf MK5 - 2004 - 2009
    Last Post: 08-02-2008, 06:18 PM
  3. 2003 mk4 golf pd tdi clutch?
    By david everett in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2007, 08:20 PM
  4. Golf TDI Mk IV (2003) clutch master cylinder
    By larderbeetle in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2007, 01:24 PM
  5. Mk3 Golf Clutch Problem
    By MarkMk3 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-03-2006, 09:46 PM
