Thread: Engine missing when cold TDI 110BHP
  1. Engine missing when cold TDI 110BHP
    Hello All
    I've just had my Bora serviced. Part of this service included a new Mas Air Flow meter because the performance had significantly dropped.
    On return from the garage I noticed that WHEN COLD, the engine would "miss" at around 2000 - 3000 revs. This goes away when the engine warms up to normal operating temperature. It now pulls very well when warm - as you would expect it to.
    I took it back to the garage - as you do - and the one fault appears - "turbo overboost" .
    The owner of the garage put some redex-type-stuff in the tank and seemed to cure it for a day but its back and after trawling through this excellent forum I cannot find exactly my problem.
    There is no problem with performance when warm - no limp mode - no miss fire - even if the engine has missed when cold. It generally only misses once but that could be to do with the fact that once its done it I generally leave the throttle alone and go along steady until the engine gets to temp.
    Thanks for any help
    A
  2. Re: Engine missing when cold TDI 110BHP
    Mar 2007
    I also have that problem with my 2001 V5 model, when it's cold it drives like crap and often 'misses' at about 2500rpm in second, but only for a very brief millisecond or so.
    Once it warms up it drives like a dream, but as it gets colder here in QLD (and it's my first Winter driving), i'm not looking forward to driving it to work when it's 15 degrees!
    08 Jetta TDi
  1. Golf TDI 90/110bhp engine query
    By william200mph in forum Golf MK3 - 1993 - 1999
    Last Post: 04-04-2008, 02:18 PM
  2. Touareg Engine Missing
    By LUV2FLY in forum Archive posts
    Last Post: 25-11-2007, 04:26 AM
  3. Noisy Golf gt tdi 110bhp, Engine 2 loud please help!
    By Jeff321 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-08-2007, 12:02 AM
  4. mk4 tdi missing, cold start,ecu fault
    By dyl_55 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-03-2007, 03:26 PM
  5. Audi Avant 90 to 110bhp engine swap
    By mikethebike in forum New Member Introductions
    Last Post: 26-11-2006, 12:46 PM
