Thread: a4 brake squeal
  1. a4 brake squeal
    Jul 2007
    i have noticed when driving with windows down a constant squeal which disappears once you apply slightt presure to brake pedal .i presume its down to pads which are pretty much as new and are gen vag ones i know there is some special grease you can use to stop the squeal ,any one used any of this and where is best place to put the grease
  2. Re: a4 brake squeal
    Glouchestershire
    I think its called copper slip greece or something like that, and you apply a smear of it to the metal back plates of the pads
    02 A4 1.9TDI quattro sport
  3. Re: a4 brake squeal
    Jul 2007
    cheers thats the name i was looking for although surprised that i may need it as reline was done only3k ago by audi brake pads still as good as new
  4. Re: a4 brake squeal
    Mar 2007
    Lancashire
    I'm not sure that that is the cause. I replaced my discs and pads with EBC greenstuff. The brakes are better, but, the boogers will squeel once warmed up. I used copper grease on them but I've research it and found that the likely cause is a glazing of the disc. Heat and some heavy braking will remove the glaze. Deposits from the pad stick in the grooves of the disc.
    It could be that you need grease. My pads came with a plastic back to avoid squeeling and a shampher to help bedding in.. the boogers still squeel so I assume it's the glazing. It goes away after some heavy braking. My normal route to work is rural roads at 40mph so I tend to be very soft on brakes most of the time.
    Try some heavy stops without coming to a complete stop.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  5. Re: a4 brake squeal
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Quote Originally Posted by Marco34 View Post
    I'd heard that about the Greenstuffs from other people - they take quiet a bit of heavy right foot/right foot action to get the results from them. A mate has some on his Elise and once they are warm you need to pick your teeth out of the steering wheel if you even dab the brake pedal so they are good, but they annoy the s**t out of you on everyday driving...
    Cheers,
    Dan.
  6. Re: a4 brake squeal
    Aug 2007
    Newport, Wales
    7 Post(s)
    On the pads I got for my S6, they already had a pad on the back to eliminate brake squeal. Isn't this standard on all VAG OEM brake pads now?
    Some mechanics just use copper grease!
    I had EBC green stuff on my Golf. I got rid of them after a while because the pads contain an element of copper which eventually deposits onto the brake disc, reducing braking performance.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  1. Nearside squeal
    By Adpro2 in forum Audi A3 - Archive Topics
    Last Post: 23-12-2007, 01:44 PM
  2. Brake prob: Car not seeing Brake Pedal
    By mo 156 in forum Bora - 1998 - 2005
    Last Post: 19-11-2007, 12:26 PM
  3. brake lights / brake switch recurring nightmare!
    By stuart40 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 11:23 PM
  4. 2005 Golf GTI clutch squeal
    By Robibbeson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-05-2007, 09:13 PM
  5. Golf 1.8 GTI - squeal when starting
    By sleekpeek in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-03-2007, 08:49 AM
