Thread: Rear Number Plate Lights - V Reg Polo
  1. Rear Number Plate Lights - V Reg Polo
    Jul 2007
    Co Durham
    Does asnybody know how to get the bulb out of the rear number plate light assembly on a V-Registered (Dec 1999) Polo? Thanks
  2. Re: Rear Number Plate Lights - V Reg Polo
    Hi Wesley
    I changed mine a couple of weeks ago.
    Firstly, take the lamp housing out of the bumper, use a small flat head screwdriver and with a bit of jiggling from the number plate side the assembly will lift out.
    Secondly, the actual bulb holder will separate from the assembly fairly easily...then you'll be able to change the bulb for a new one.
    Once done you'll be an expert number plate bulb changer...it's an easy job for sure
    Good Luck!
  3. Re: Rear Number Plate Lights - V Reg Polo
    Jul 2007
    Co Durham
    Thanks - didn't realise it was so easy!
  4. Re: Rear Number Plate Lights - V Reg Polo
    No Worries
  5. Re: Rear Number Plate Lights - V Reg Polo
    May 2009
    Auckland New Zealand
    Hi: For the benefit of anyone else searching, my 1996 Polo, where to get the light housing out required lifting up the back of the unit slightly, putting a thin screwdriver horizontally underneath from the back, and running it down the left hand side to find a springy metal strip, move that strip in towards the middle of the unit, which allows the whole unit to unclip from inside the bumper.
    The reason for my light not working turned out to be severe corrosion of the bulb holder, so now we are looking for more than just the bulb!
    hth
  1. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
  2. Rear Number plate mountings
    By sherlockuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2008, 02:50 PM
  3. 51, 1.8T Passat - Number Plate Lights
    By martyn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-09-2007, 03:40 PM
  4. Number Plate Lights???
    By bogey888 in forum Audi A3 - Archive Topics
    Last Post: 02-02-2007, 02:04 AM
  5. Passat Rear Number Plate
    By keaveney911 in forum Passat - Archive Topics
    Last Post: 17-12-2006, 08:05 PM
