Thread: Cam shaft position sensor 1.8 GTI
  1. Cam shaft position sensor 1.8 GTI
    Mar 2008
    Original thread:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=30827
    Had news back from the garage that the cause of the above was the cam shaft position sensor, well not the sensor itself as they've replaced that but the wiring/contacts to the ECU. Could anyone tell me what this does and would this cause poor performance and high fuel consumption?
    Also, how difficult is it to find a wiring fault in this loom and where is it located?
  2. Re: Cam shaft position sensor 1.8 GTI
    Kings Lynn
    I'm not sure what engine yours has in it but this is some info on a AGU engine (1.8T, 150bhp)
    The camshaft sensor (not 100% without seeing it) should be behind the front camshaft sprocket, under the timing belt cover, but i think they have a wire on them heading towards the front of the engine. The wires to the sensor should be as follows; violet and red to pin 1, violet and yellow to pin 2, brown and blue to pin 3.
    The Engine E.C.U is underneath the scuttle panel (under the wiper arms)(worth checking and cleaning the earth point infront of it) and the pins relating to the camshaft sensor are as follows. from camshaft sensor (to) Engine E.C.U
    pin 1: pin 62 (also goes to TPS and Baro Sensor)
    pin 2 : pin 76
    pin3 : pin 67 (also goes to ECT, IAT, CKP, both KS, CTP, TP, ISC, BARO Sensor.)
    make sure the e.c.u is disconnected before probing with a multimeter, and the battery is disconnected before the e.c.u
    The wires should be the same colours at camshaft sensor and e.c.u.
    Hope that helps!
  3. Re: Cam shaft position sensor 1.8 GTI
    Mar 2008
    Thanks for the notes. Would this cause the under performance and high fuel consumption?
  4. Re: Cam shaft position sensor 1.8 GTI
    Mar 2008
    Sorry, forgot to say it's an AUG 1.8 turbo engine.
    The garage said it's a hard fault after changing the sensor. They have also changed the AMM.
  5. Re: Cam shaft position sensor 1.8 GTI
    Kings Lynn
    Sorry i can't find any info on a AUG engine, but bad connections or crimped wires can cause alsorts of problems.
    The cambelt itself could cause bad fuel economy, and lack of power. It might just be that the camsensor is detecting that the camshaft is out of alignment of the crankshaft, caused by incorrect tension of the belt or mis-aligned timing.
    hope that helps.
  6. Re: Cam shaft position sensor 1.8 GTI
    Mar 2008
    That was my concern from the original work I had done following the blocked oil strainer - see original thread on the first post. The guy at the garage said that he took the rocker cover off and inspected the cam but no damage. Could he have disturbed something there?
    Now the guy at a different garage is saying that there is a hard fault with the cam sensor despite fitting a new sensor.
    Help, please!
  1. throttle position sensor?
    By lee07 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2007, 06:07 PM
  2. crank shaft sensor problem
    By craigbeal in forum Archive posts
    Last Post: 19-08-2007, 10:58 AM
  3. Cam Position Sensor
    By zenmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2007, 10:57 AM
  4. Throttle position sensor
    By j_coupland in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-11-2006, 12:29 PM
  5. Mk3 Golf TDI throttle position sensor
    By j_coupland in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2006, 05:09 PM
