Thread: Cheap VAG COM options for a novice
  1. Cheap VAG COM options for a novice
    Mar 2008
    Leiderdorp, Netherlands
    I have just bough a 1999 golf 4 1.6 AKL engine which has lots of problems and am starting to realise that in order not to be ripped off by the VW dealers and others I need to be able to do things myself which means that I need to be able to detect faults and clear them plus one or two other basic functions. I need some advice on the best and most cost effective software and cables to use. I also own a 2003 Polo so would like to get something that is compatible. Any help would be great.
  2. Re: Cheap VAG COM options for a novice
    cheap option would be to buy a third party cable off ebay for around £10 dont pay more than £15 in total. and download the shareware version of vagcom from ross-techs website this allows you to read and clear codes as well as a bit more, but not much.
    once you get the hang of it get a license for it its about £50 at current this allows you into the more detailed sections
    such as the shareware version for engine allows you to measure blocks no 1 - 20 whereas the full version allows you all of them
  3. Re: Cheap VAG COM options for a novice
    Mar 2008
    Thanks, I have been checking the options out and it seems that there are plenty of connectors that are compatible with vag com 409.1 is this sufficient or should I go for one which is compatible with later software versions?
  4. Re: Cheap VAG COM options for a novice
    Lansdale, PA, USA
    Your car is a 1999 model. Version 409 is a from 2004. There are a few exceptions, but a good rule of thumb is that the software you're using should not be older than the car. In this case, you've got plenty of safety margin on that rule.
    -Uwe-
    www.Ross-Tech.com
    Satisfaction guaranteed or double your fault codes back!
  1. new A3 novice in town
    By eluminati in forum New Member Introductions
    Last Post: 25-01-2008, 02:12 PM
  2. A4 tdi cheap family car?
    By markquinton in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-07-2007, 08:06 PM
  3. Going cheap now... !!
    By RickT in forum Phaeton
    Last Post: 27-04-2007, 06:13 PM
  4. Cheap parts?
    By cookie_monster in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-07-2006, 11:26 PM
