Thread: problems with my 1.9dti
Results 1 to 10 of 11
  1. problems with my 1.9dti
    i have just bought a 1996 a4 1.9tdi 90bhp model,im having a few problems with the car.as far as i can see there is no engine management light coming on when i first turn on the ignition
    the first is the temp gauge does not work,could this be a sensor fault or something more expensive? i dont have any starting or running problems,which and where is the water temp sensor? i have found three single pole sensors on the back of the cylinder head on an housing,i have also found a blue plug that is plugged into nothing.this plug is near the rear of the engine bay on the centre line of the car,i cannot find anything that the plug could go into
    the second is if i leave the ignition switched on without starting the engine the oil and water lights flash,does this indicate a problem? once today the water light came on for a few seconds,the engine was cold and hasnt came on again.the oil light does not come on when the engine is going
    third the abs does not work,the light on the dash does not come on either so either a fuse has been removed or the bulb has been removed,is there any common problems that stop the abs working other than sensors
    fourth problem is you cannot turn the heater control knob (non air con) to make the air go to the screen,is there anything that can do this,or is it just a case of adjusting the cable
    sorry about so many problems and questions but i need to get the problems sorted as i need to make sure this car is reliable so any answers would be appreciated
  2. Re: problems with my 1.9dti
    anyone help? as i had another problem in that the car wouldnt start today,it would try to but cutout,i left the ignition on and there was a buzzing from the fuel pump,i turned off the ignition and retried and the car started,i dont have a visible management light either
  3. Re: problems with my 1.9dti
    anyone??? i need to get this car fixed asap,i think i have made a big mistake buying this car
  4. Re: problems with my 1.9dti
    does anyone know a site than answer my queastions,if i had a vauxhall or citroen there are forums that answer usualy in a couple of hours,at this rate i might actualy keep the citroen that i also have.sorry but this car is starting to p*** me off
  5. Re: problems with my 1.9dti
    North Lincolnshire
    Sorry no-one has answered you.
    Firstly it appears that there has indeed been some tampering with your dash lights, unless there is a plug/connection loose behind your clocks.
    You should really get someone with Vag-Com to scan your ecu for faults.
    As for your ABS light, does it light up when you turn your ignition on ? Have you definately got ABS ? If so, it is an MOT failure if the light does not come on with your ignition then go out.
    You really need a scan with Vag-Com or a decent scanner to check all this.
  6. Re: problems with my 1.9dti
    Quote Originally Posted by jkay2008 View Post
    the car does have abs and the light does not come on the dash,the car has only just passed an mot! tomorrow im going to remove the clocks and inspect the bulbs
    the vag-com cables on ebay,do they work?
  7. Re: problems with my 1.9dti
    North Lincolnshire
    I am in the motor trade, and it is definately an MOT failure, I have just had one fail for the same thing ! Someone had taken the bulb out coz there was a fault.
    The aftermarket cables are ok for a very limited functionality on an old version of vag-com. A lot of the functions are disabled. They are worth a try for a tenner tho.
    I have the latest edition, official Ross-Tech cable, but they arent cheap. Saying that, they are worth every penny.
  8. Re: problems with my 1.9dti
    yes i know it is an mot faliure,problem is i cant prove that the abs wasnt working at the time of the mot,car passed mot on 7th april and still has just over a year to run,i could report the garage but it is my word against theirs so a waste of time,i have an idea what and why they have done it,i found a card with a name of a garage that does diognostics,may be worth giving them a ring to see if the last owner did use their services,i dont have an engine management light either
  9. Re: problems with my 1.9dti
    im realy annoyed that someone has gone to this much effort to sell the car,it has had a lot of money spent on it,has had several front arns changed,supposedly a new water pump,do you know what sensor does the temp gauge(there are 3 at the back),also with the ignition on,engine off are the oil and water temp lights supposed to flash?
  10. Re: problems with my 1.9dti
    Apr 2007
    Norfolk
    Quote Originally Posted by solorider View Post
    Hi, ive got a 97 tdi and the lights on mine flash untill the car is started..... its normal.
    The water temp gauge uses a sensor at the back of the engine which is fitted into one of the hoses.... the sensor is blue in colour. If you take the black plastic engine cover off you should be able to locate it.
    Incidentally this sensor also supplies the ecu, telling it the coolant temp.... if this sensor fails it can cause poor running/starting.
  1. a3 1.9dti air in fuel problem
    By ianrudge in forum Audi A3 - Archive Topics
    Last Post: 30-03-2006, 03:46 PM
