Thread: Problems with our A4 :(
Results 1 to 10 of 16
  1. Problems with our A4 :(
    Mar 2008
    Wales
    Hi all,
    Wondering if anyone can help with some problems we have been havng with our A4.
    Since buying it a few months back we have noticed that the display that shows you how hot you have the heaters and how high you have them is forever more knocking off (the display). You have to press hard in a certain place to see what the temperature etc is at. We have also noticed that occasionally the dash will black out (hasn't done this for a while now) and most recently the heaters have stopped working, you have to kick a certain part on the passengers footwell for them to start working.
    The car is a '96 (I think) and covered just over 180k.
    Anyone have any idea what could be causing the problems? We have thought electrical problems but not sure what it could be tbh and dont fancy going through all of the electrics.
    Jow
  2. Re: Problems with our A4 :(
    Apr 2007
    Lancashire
    The fan problem may be seperate to the climate display issue?
    Try replacing or turning the fan motor brushes round, as the fan will stop working when they become worn. (a bang on the dash can make the motor start)
    https://www.vwaudiforum.co.uk/forum/s...ghlight=Blower
    This article may also help with the heater display issue?
    http://www.audiworld.com/tech/elec153.shtml
  3. Re: Problems with our A4 :(
    Mar 2008
    Wales
    I have no doubt that the issues are separate
    Thank you for the links, I shall be taking the car apart tomorrow and seeing if thats the problem, as for the other one, I think we can cope with the display not working properly lol, I am not soldering that! (well, depends how much it frustrates me )
  4. Re: Problems with our A4 :(
    Apr 2007
    Lancashire
    If the display is still working it may just be the bulbs?
  5. Re: Problems with our A4 :(
    Mar 2008
    Wales
    The display works, it just flickers quite often or wont work unless pushed quite firmly, which lead us to believe bad connection. We can live with it for now
  6. Re: Problems with our A4 :(
    metalmickey Guest
    I'm about to brave resoldering/replacing the climate control panel but my car has an aftermarket stereo fitted and so the screws in the above diagram are covered by a fascia adaptor...
    Daft question, but how do you get those fascia adaptors out? Do they just clip in?
  7. Re: Problems with our A4 :(
    Mar 2008
    Wales
    most of them do
  8. Re: Problems with our A4 :(
    metalmickey Guest
    I'll bray it out and let you know how I get on!!!!
  9. Re: Problems with our A4 :(
    Mar 2008
    Wales
    Quote Originally Posted by metalmickey View Post
    heh, if its anything like soldering a new power port into my laptop I'm not in a hurry to repeat but would be great to know how you got on and if its as bad as it seems.
  10. Re: Problems with our A4 :(
    It's an easy soldering job, just did it in my new(to me) 1996 1.8... I can talk you through no probs
