Thread: Engine fire's but wont run.
Page 6 of 6 FirstFirst ... 456
Results 51 to 53 of 53
  1. Re: Engine fire's but wont run.
    #51
    Mar 2008
    HI there. You mean a VAGCOM license???
    Ah - that was my very next step! I might even buy the license anyway, as it's SO useful having this kit. I think the cheapest license is $99, which is about £45. Not bad considering you can diagnose faults and clear codes and airbag light etc... I'm still a bit worried about disconnecting the battery. Fair enough, mine was off for 50 hours! but I wonder what would happen if I simply disconnected the neg lead for 5 mins???
    I've still got the ln2 flashing up underneath the mileage counter though. I think she's due a timing belt change. Anyone know why I still get the ln2 service indicator flashing up, but no other lights or VAGCOM fault codes?
    Thanks!
  2. Re: Engine fire's but wont run.
    #52
    Apr 2007
    Lancashire
    In2 = Inspection Service 2 (major service)
    In1, In2 and Oil reminders can all be reset with vagcom.
  3. Re: Engine fire's but wont run.
    #53
    I only had battery off for 10 hours or so, and had been doing that for about 6 times over several weekends as car was sat not moving. This was the first time i had a problem, dont know if i put a spike thru electrics.
    Vagcom with license and 10 mins and all sorted. Best $99 I ve spent, (local locksmith wanted £45 just to show up).
    Be careful if you have aftermarket radio, check Rosstech site for details of12V on K-line (not sure if it applies to your car but best to check)
    I followed the procedure on rosstech wiki that details what to do when you change immo box, basically gets the immo box to re-learn keycodes, (you will need 4 digit skc number).
    Next job is trying to find whats draining battery!!!!!!!!!!!!!
    Good luck
  1. Randomly wont start, not turning engine over.
    By zoro in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2008, 09:36 PM
  2. Engine Cuts out / Wont Start
    By james_101 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-10-2007, 10:16 AM
  3. vento engine wont start
    By norton in forum Vento - 1994 - 1998
    Last Post: 25-07-2007, 10:23 PM
  4. Washed engine, now wont start
    By abc123 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-07-2007, 04:27 PM
  5. vw golf engine starts but wont run
    By des1210 in forum Archive posts
    Last Post: 09-07-2007, 11:12 PM
