Thread: 2002 Jetta Wagon OBD II P0321
  1. Question 2002 Jetta Wagon OBD II P0321
    Mar 2008
    Hello,
    I am a first time VW driver and first time reader here.
    I have a 2002 Jetta Wagon 5 speed that I've had for about a week
    and have driven over 500 miles no problem. I ran the car out of gas
    thinking the reserve was more than it was and after putting a few gallons
    of gas in the tank, she doesn't want to start but will with much effort
    and the EPC light is on as well as the check engine. I recovered a code
    from the ECU for P0321. Any ideas anyone?
    David
    P.S.
    I put this post here as I couldn't find a thread dedicated to the year amd model I have.
  2. Re: 2002 Jetta Wagon OBD II P0321
    ireland
    po321 is ignition/distributor engine speed input circut range/performance......not sure what this means,
  3. Re: 2002 Jetta Wagon OBD II P0321
    Mar 2008
    After replacing the engine speed sensor/impulse sensor I tried
    to start the engine, but no change, still will not start. Just cranks.
    I checked for spark and it was very weak so I swapped my coil
    with a friend who has the same year, same engine same manual
    trans Jetta and my car started but that is it. Starts and dies.
    Starts and dies. no matter hiw many times I start it.
    The engine speed sensor/impulse sensor was bad, I checked
    for the 400-1000 ohms resistance between pin 1 & 2 but I had infinite
    resistance so I know that part was bad. I can smell fuel so I am guessing
    that isn't an issue. I checked the injector pulse with a noid light and they
    fire normal.
    Someone on another forum asked me about the immobilizer
    and I told him the key symbol on the dash started flashing when
    I start the engine, or try to start it...what does a flashing key
    symbol mean anyway?
    Quote Originally Posted by paulp View Post
  1. Paddy Wagon
    By devsgolf in forum Chat - Completely Off Topic
    Last Post: 07-04-2008, 09:15 PM
  2. 2002 Jetta
    By mjarret1 in forum New Member Introductions
    Last Post: 26-02-2007, 02:40 AM
  3. 2002 Jetta heater rheostat stuck on hot (bora uk)
    By mjarret1 in forum Bora - 1998 - 2005
    Last Post: 26-02-2007, 01:13 AM
  4. Changed Sparkplugs on 2.0 Mk 4 Wagon..
    By Snowdance38 in forum Bora - 1998 - 2005
    Last Post: 15-09-2006, 01:53 AM
