Thread: ROPEY WINDOW.
Results 1 to 10 of 11
  1. Angry ROPEY WINDOW.
    Nov 2006
    CHESHIRE
    I HAVE GOT A PROBLEM WITH MY 2001 TDI PASSAT SPORT,THE DRIVERS FRONT WINDOW WILL NOT GO UP OR DOWN,AND IS MAKING PROPER NASTY NOISES ,THE MOTOR SEEMS TO BE WORKING BUT IT SOUNDS LIKE A CABLE HAS SNAPPED OR COME A DRIFT ANY IDEAS ?.
    Don't know about the mechanism on a Passat. But had a similar problem on a MKIII Golf. The drivers window got smashed & the radio nicked. The glass got in to the mechanism and frayed the cable. It worked for a while after the glass got replaced but then struggled to go up and down and made a hell of a noise. I replaced the mechanism myself. I don't know how much of a DIY'er you are. You could remove the trim and have a look. I could see where the cable was damaged on the Golf.
    Regards Boardboy.
    Canada
    This is a bit vauge but I read somewhere that mk4 golfs have a habbit of breaking a plastic part in the mechanism, It may be the same for the passat. Suggest you do a search to see if other have had a similar problems. I recall that the part was not too expensive.
    Give the local dealer partd dept a ring, they are pretty good at identifying common faults.
    Rob
    Nov 2006
    CHESHIRE
    THANKS FOR THE ADVICE,SORTED NOW REGARDS GARY.
    Nov 2006
    CHESHIRE
    CHEERS MATE ,JOB DONE ,REGARDS GARY.
    Canada
    Just for reference How did you fix it?
    Rob
    Nov 2006
    CHESHIRE
    THE CABLE HAD COME OFF ITS RUNNER 30 MINUTE JOB. REGARDS GARY
    Canada
    Great I like the inexpensive jobs, just good to know the out come when people are searching for fixes.
    Happy Motoring
    Rob
  1. Electric Window
    By LLX in forum Polo - Derby - Lupo - Fox
    Last Post: 20-04-2007, 11:49 PM
  2. Window Tinting
    By benGT in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 21-02-2007, 05:23 PM
  3. Window sensor
    By grahamben98 in forum Audi A3 - Archive Topics
    Last Post: 28-01-2007, 12:44 PM
  4. WINDOW
    By GARY in forum Passat - Archive Topics
    Last Post: 24-01-2007, 09:21 PM
  5. Window ECU
    By NickHuge in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-12-2006, 02:23 PM
