Thread: engine speed sensor , vag com
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. Re: engine speed sensor , vag com
    #21
    chester
    would something like this be hard to find as my car been at independant vw garage for 7 months now and not be able to locate fault .
  2. Re: engine speed sensor , vag com
    #22
    134 Post(s)
    2007 Post(s)
    Plus or including VAT?
  3. Re: engine speed sensor , vag com
    #23
    May 2007
    knee deep in clunge
    14 Post(s)
    id tell your workshop to run some wiring along the exsisting wiring for this circuit and try that,i presume they have checked all the wiring for resistance and mutual shorting.Difficult fault to cure without eliminating the wiring and earth points.Idea with very advanced wiring on audi a8,q7 etc and most faults i find are actual loose pins or loose earth points which drive me mad in the ed
  4. Re: engine speed sensor , vag com
    #24
    chester
    crasher 55 pound 40 for speed sensor , 40 pound labour and total of 112.09 with vat mate
  5. Re: engine speed sensor , vag com
    #25
    134 Post(s)
    2007 Post(s)
    Well a genuine G28 sender is £66.60 inc. VAT (my price list is slightly out of date) and a G40 sender is £24.25 so the sender cannot have been genuine.
  6. Re: engine speed sensor , vag com
    #26
    chester
    crasher , thanks for that i will check with garage on tuesday . i took it to small side street garage and they put new speed sensor on first but when it never worked i took it to ind vw garage where it has been for months and that was the first thing they checked , that it was a genuine part . do you think it could have the wrong sensor fitted then as they said same things as you that vw manual says to change ecu .
  7. Re: engine speed sensor , vag com
    #27
    134 Post(s)
    2007 Post(s)
    Well the ECU and sensor have been changed and the wiring checked so that is the system. Now the possibility of a fault with the speed sensor ring has to be investigated so the next step would be to remove the gearbox, clutch and flywheel to examine and replace the sender wheel. This is a complex process that must be carried out using a special VW tool or the correct positioning of the sender cannot be guaranteed. One thing, has it had a clutch or flywheel oil seal replacement?
  8. Re: engine speed sensor , vag com
    #28
    chester
    craher im not sure if its had a new clutch or seal as my girlfriend bought it when i was on holiday last year . she drove it for about a week before this started and its just gone from there mate . not sure if its worth fixing then as that sound like big job and i spent alot trying to get it running for her already . how much would it cost to check it do you think
  9. Re: engine speed sensor , vag com
    #29
    134 Post(s)
    2007 Post(s)
    It is a good six hours labour, plus part (£63) and the tool would need to be bought but I have no idea how much the tool is, I would guess at £100 or so. The clutch has to come off so as these are highly unreliable on these I would also fit a new clutch, another £100 ish.
  10. Re: engine speed sensor , vag com
    #30
    chester
    ok thanks mate ill speak to garage on tuesday , is there no way of checking before you take the clutch and gearbox out and what if its not that .
  1. 2.5 Tdi engine speed sensor for diesel pump
    By adamss24 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-01-2008, 08:12 PM
  2. A4 TDI - Engine Speed Sensor
    By philb80 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2007, 05:49 PM
  3. ABS - wheel speed sensor (s3)
    By Jon_Halibut in forum Audi A3 - Archive Topics
    Last Post: 15-06-2007, 03:08 PM
  4. Engine Speed Sensor - A4 TDI
    Last Post: 14-05-2007, 09:49 PM
  5. Engine Speed Sensor - A4 TDI
    By philb80 in forum Archive posts
    Last Post: 05-05-2007, 09:22 AM
