Thread: engine speed sensor , vag com
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. engine speed sensor , vag com
    chester
    my 2001 1.4 vw polo has been read by vag com at independant vw garage . the fault code is 10606 engine speed sensor G28 intermittent no signal . the garage have had car for months and cannot find the fault . It runs fine when fault is deleted but when restarted a couple of times you hear relay 410 of the fuel pump clicking like mad as soon as you hear this the ecu, oil light and clocks stop working . they changed the relay for fuel pump , it has had new ecu , engine speed sensor , crank sensor, coil , new clocks but still the same . they have checked wiring and is ok they say . last week they said they fixed it and it was clocks but sadly it was not . they have contacted bosch and they say its possibly to do with high frequencies of something affecting engine speed sensor , as it is to close .i m starting to think now that the speed sensor fault code is taking them up the wrong alley but im not sure . has anybody heard of this or could anybody possibly shed any light on this bad headache for me , thanks john
  2. Re: engine speed sensor , vag com
    134 Post(s)
    2006 Post(s)
    Can we have the engine code and the chassis year, wvwzzz6Nz ? Y000000
  3. Re: engine speed sensor , vag com
    chester
    engine code is WVWZZZ6NZ1Y039016 and chasis yr is y214tkl , thanks is this imformation right mate
  4. Re: engine speed sensor , vag com
    chester
    where do you get engine code
  5. Re: engine speed sensor , vag com
    chester
    engine no is AUA029010
  6. Re: engine speed sensor , vag com
    134 Post(s)
    2006 Post(s)
    WVWZZZ6NZ1Y039016 is the chassis number which is perfect for me, back in a moment.
  7. Re: engine speed sensor , vag com
    134 Post(s)
    2006 Post(s)
    10606 engine speed sensor G28 intermittent no signal doesn’t exist, it must be “16706 (P0322) Engine speed sender -G28 no signal” or “17806 (P1398) Engine speed signal, TD short to earth”
  8. Re: engine speed sensor , vag com
    chester
    thats what they told me it was mate , sorry have to get back on to them tomo ,and get back to you .
  9. Re: engine speed sensor , vag com
    134 Post(s)
    2006 Post(s)
    OK, try and get a print out of the code next time they do a scan.
  10. Re: engine speed sensor , vag com
    chester
    they said the fault code is 16706 engine speed sensor crasher . i spoke to them last week and they said it was a signal cutting out fuel pump but they dont know why
  1. 2.5 Tdi engine speed sensor for diesel pump
    By adamss24 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-01-2008, 08:12 PM
  2. A4 TDI - Engine Speed Sensor
    By philb80 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2007, 05:49 PM
  3. ABS - wheel speed sensor (s3)
    By Jon_Halibut in forum Audi A3 - Archive Topics
    Last Post: 15-06-2007, 03:08 PM
  4. Engine Speed Sensor - A4 TDI
    Last Post: 14-05-2007, 09:49 PM
  5. Engine Speed Sensor - A4 TDI
    By philb80 in forum Archive posts
    Last Post: 05-05-2007, 09:22 AM
