Thread: Polo Fox Freg Gear box
  1. Polo Fox Freg Gear box
    Oct 2007
    Hi, I`m a bit stuck and need some help.
    I drive a Polo Fox F reg 1050cc. 2 door hatch. I thought I would check the Gearbox oil level. Found a star drive bolt on the front face of the gearbox and thought it might be a filler/level hole. took the bolt out (thinking "Its not in a good place and why is it so long) and oil duly came out (Happy) Put the bolt back in and could not get 1st or second gear (Not happy) Let it back out again and got the 1&2nd gears back but no reverse.(Well now and then) I have a Haynes manual. But it has no real information to help with the gearbox.
    If I could just get an exploded view of the workings of the gearbox layout I could see whats happening and know what to do. Or It may be just a case of putting the gear leaver in the correct place before putting the bolt back in. (Fingers crossed).
    Many thanks for any help in advanced. Tom.
  2. Re: Polo Fox Freg Gear box
    Oct 2007
    Any one got a parts drawing of my gearbox?
  3. Re: Polo Fox Freg Gear box
    have someone hand you an exploded view? i need one to. same misstake not good... talked to an expert today and he told me that i have to open the box... POLO 1,4 2000(cheap just now :-))
  4. Re: Polo Fox Freg Gear box
    Oct 2007
    No drawing of the gearbox yet. Still driving without reverse. If I get a drawing I will let you know.
  5. Re: Polo Fox Freg Gear box
    May 2007
    knee deep in clunge
    14 Post(s)
    you have dropped the gear selector fork and it would mean removing the box and the bell housing and realigning the fork and preying no damage has occured.
    vag diagnostics, retrofits and general repairs
  6. Re: Polo Fox Freg Gear box
    Oct 2007
    Thanks a8 tech, I found a mechanic who said the very same thing. But this was after driving around for 3 months with no reverse much to the amusement of all and then finally getting someone to slowly tighten the bolt back up while I waggled the gear lever around in reverse. The mechanic said I was very lucky.
    Alls well that ends well
  1. 93 Polo CL Coupe Gear Box Oil Filling Point
    By VWPeoplePower in forum Polo - Derby - Lupo - Fox
    Last Post: 20-09-2007, 01:52 PM
  2. Polo Lost 5th Gear
    By jdabney in forum Polo - Derby - Lupo - Fox
    Last Post: 19-07-2007, 10:46 AM
  3. 1st gear difficult on POLO.
    By donal mc carthy in forum Polo - Derby - Lupo - Fox
    Last Post: 23-06-2007, 10:26 PM
  4. Help Please! 1st gear jumps out of gear
    By TollyTDI in forum Toledo
    Last Post: 17-06-2007, 07:50 AM
  5. Gear jumps out and non smooth gear changes
    By RIZWAN180 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 09:45 AM
