Thread: Noise on full lock
  1. Noise on full lock
    Jul 2007
    I have noticed today a grating noise when I put the steering on full lock and move off, can't see anything!
    It had a service last week at 37K and it has to go back as they tried to fix a dashboard rattle which now rattles worse under acceleration So I will ask them to look at it, just wondering if anybody else had noticed similar?
  2. Re: Noise on full lock
    sathound Guest
    Mine did this from new on full right lock. It turned out to be the inner part of the tyre rubbing on the inner wing liner which had become unclipped and had distorted. VW wanted me to purchase a new inner wing liner but I got them to perform a temporary fix and that worked fine for 12000 miles until I went through a farly deep flood which has caused the issue to re-appear.
  3. Re: Noise on full lock
    Apr 2007
    France
    12 Post(s)
    Check some of the other posts for a cure for the dashboard rattle - it can be done.
    If sathound's suggestion isn't your problem, check the lock stops. Also there have been problems with the steering racks on some cars, but I'm not sure if your symptoms are the same.
  4. Re: Noise on full lock
    Dublin, Ireland
    Could be a CV joint.
    Go to an isolated Car Park. Put the car into full lock left and drive with the window down in first gear. Then do it left....
    If you get a clicking noise on either lock then the CV joint in that side of the car is buggered and needs replacing.
    You can DIY it but I've never had the patience. Garage should do it for a few bob.... Nothing that will break the bank.
    VW Passat '03 1.9 TDI Comfortline
    Skoda Fabia '03 1.2 Comfort
    Honda Civic '92 1.6
  5. Re: Noise on full lock
    Quote Originally Posted by sathound View Post
    I had that problem as well, but VW reattached it under warranty and it hasn't recurred.
    Might be worth a look if any driver is experiencing a noise on or near full lock.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  6. Lightbulb Re: Noise on full lock
    My Sport 170 Manual Estate does this and I thought it was the creaking of the CV Boot(s) which being made of Rubber or EPDM, naturally creak a bit when flexing as they would on full lock.
    However, after reading this thread I will now check underneath me arches !
    Thanks guys !
    Regards
    claranet
  7. Re: Noise on full lock
    My car was at VW today for the same noise and it turns out to be the top mount and spring rubbing apparently a known problem. Anyway they informed that the parts will be ordered today although they are on back order. Nothing to worry about I was informed.
    I will let you know when its done
  1. mk4 steering noise on full lock
    By mk1 Bob in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2009, 09:20 AM
  2. knocking on full lock audi s4
    By rpg.7l in forum Archive posts
    Last Post: 24-01-2008, 01:35 PM
  3. Full Lock
    By Ruairi_Trainor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-12-2007, 09:45 PM
  4. Help needed with noise on full steering lock?
    By markcass in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2007, 08:22 AM
  5. Polo - strange noise when turning/full lock right
    By Dreamertae in forum Polo - Derby - Lupo - Fox
    Last Post: 18-07-2007, 09:14 PM
