Thread: Temperature Gauge Drops
Results 1 to 10 of 10
  1. Temperature Gauge Drops
    I Have 1.8 Gti T
    Just Lately The Temp Gauge Drops Right Down Then Goes Back Up.
    No Water Loss At All,
    Any Ideas,
    Many Thanks
  2. Re: Temperature Gauge Drops
    Mar 2008
    i dunno but my mk4 has the same problem, let me know if you find it
  3. Re: Temperature Gauge Drops
    Mar 2007
    U-96
    Try two of these;
    Once in the morning, and one before going to bed ?
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=30352
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=29512
    Check your medication is green, not black
  4. Re: Temperature Gauge Drops
    Mar 2008
    ha ha tanx tornado
  5. Re: Temperature Gauge Drops
    Mar 2007
    U-96
    Shakey,
    You're welcome. If your moniker refers to your hands, I hope you're not a surgeon
    If it is the temperature sensor (you can check VAG-COM fault codes), the medication you probably require is;
    • 059.919.501.A [dual temperature sensor/sender, green not black]
    • 032.121.142 [retaining spring, in case you damage the original one]
    TR7
  6. Re: Temperature Gauge Drops
    Mar 2008
    cheers, ill hav a look at it, not d worst of my problems rite now tho, still hav to change a wheel, get one repaired, find oil leak, figure out why my dash lights dim wit the engine, buy a second door lock, a load of electrical bulbs, includin rear window heater elements.....nd drive it off a cliff
  1. Temperature gauge!
    By tenorio74 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-03-2008, 04:10 PM
  2. Temperature Gauge
    By Brian Rouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2008, 05:54 PM
  3. Temperature gauge
    By SPRINGLE68 in forum Audi A3 - Archive Topics
    Last Post: 02-12-2007, 11:31 PM
  4. 2.5 TDi V6 Temperature Gauge
    By lennymfo in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-12-2007, 10:34 AM
  5. temperature gauge
    By cat69 in forum Archive posts
    Last Post: 10-11-2006, 10:23 PM
