Thread: Temperature Gauge Drops
Results 1 to 10 of 10
  1. Temperature Gauge Drops
    I Have 1.8 Gti T
    Just Lately The Temp Gauge Drops Right Down Then Goes Back Up.
    No Water Loss At All,
    Any Ideas,
    Many Thanks
  2. Re: Temperature Gauge Drops
    Mar 2008
    i dunno but my mk4 has the same problem, let me know if you find it
  3. Re: Temperature Gauge Drops
    Mar 2007
    U-96
    Try two of these;
    Once in the morning, and one before going to bed ?
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=30352
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=29512
    Check your medication is green, not black
  4. Re: Temperature Gauge Drops
    Mar 2008
    ha ha tanx tornado
  5. Re: Temperature Gauge Drops
    Mar 2007
    U-96
    Shakey,
    You're welcome. If your moniker refers to your hands, I hope you're not a surgeon
    If it is the temperature sensor (you can check VAG-COM fault codes), the medication you probably require is;
    • 059.919.501.A [dual temperature sensor/sender, green not black]
    • 032.121.142 [retaining spring, in case you damage the original one]
    TR7
  6. Re: Temperature Gauge Drops
    Mar 2008
    cheers, ill hav a look at it, not d worst of my problems rite now tho, still hav to change a wheel, get one repaired, find oil leak, figure out why my dash lights dim wit the engine, buy a second door lock, a load of electrical bulbs, includin rear window heater elements.....nd drive it off a cliff
  7. Re: Temperature Gauge Drops
    Mar 2008
    oh and get another key cut....
  8. Re: Temperature Gauge Drops
    blackpool england
    reading the above and the links, seems like my mk4 has the same problem, can anyone tell me the locatation the sensor?
    thanks
    ross
  9. Re: Temperature Gauge Drops
    hi,
    looking at the engine its on the right hand side,
    of the block,its got a push on block,just under the wireing block there is a push in clip it just holds the sensor in place,very easy to do,about £10 on ebay,i was told to buy the green sensor instead of black i don't know why,
    hope this helps
  10. Re: Temperature Gauge Drops
    blackpool england
    thanks for the reply im sure it will make sense when i attempt to do it!
    cheers
  1. Temperature gauge!
    By tenorio74 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-03-2008, 04:10 PM
  2. Temperature Gauge
    By Brian Rouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2008, 05:54 PM
  3. Temperature gauge
    By SPRINGLE68 in forum Audi A3 - Archive Topics
    Last Post: 02-12-2007, 11:31 PM
  4. 2.5 TDi V6 Temperature Gauge
    By lennymfo in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-12-2007, 10:34 AM
  5. temperature gauge
    By cat69 in forum Archive posts
    Last Post: 10-11-2006, 10:23 PM
