Thread: Front wheel bearing replaced - what have they got wrong?
  1. Front wheel bearing replaced - what have they got wrong?
    1996 Passat saloon, 158,000 miles.
    I had a front wheel bearing replaced four weeks ago. I noticed today that both front tyres were extremely worn on the inner edge, and suspected the tracking was out.
    After I had the bearing done the handling felt a bit twitchy, and also the steering wheel was crooked. I was worried about the handling yesterday, as it was getting worse, which is why I checked the tyres today.
    The tyres were fairly old, and would have needed changing within a few months anyway, so it was not a disaster.
    I phoned up the place where I had the wheel bearing done, and they said that replacing a bearing does not affect the tracking.
    I went to a local tyre place today bought two new tyres and had the tracking checked. The toe-in should have been 0 degrees, and in fact was -14 degrees. The chap said he had never known it that far out. After he pointed it out I could see it with the naked eye. He had a lot of trouble getting it back to zero, including using a blowtorch to free both sides up.
    I intend to go back to the place that did the wheel bearing, and claim the full cost of the tracking, part cost for the new tyres, and some compensation, but I am worried there is something seriously wrong with the car. Did they put the suspension back together wrongly? Is it likely to fail in a big way? I can't believe they could adjust something so badly, and they deny they adjusted it anyway.
    Chris Melluish
  2. Re: Front wheel bearing replaced - what have they got wrong?
    Hi When replacing a wheel bearing, if the swivel joint is dismanteled by loosening the 3 bolts which the swivel joint is screwed to the suspension link,this is not the right procedure however if done that way the following must be done. Mark installation position; set to centre of elongated hole and check toe setting.
    Elongated holes are not used to set camber! Non-observance may damage drive shafts.
  3. Re: Front wheel bearing replaced - what have they got wrong?
    Dec 2007
    The Haynes manual gives unbolting the suspension strut , lower swivel and track rod end as the method for replacing the wheel bearing. I have done mine this way , marking / scribing the component positions as described in the book.
    Once they are taken apart the hole tolerances have to be seen to be believed.
    Cocking up the re-assembly positions can alter both the tracking and camber-so
    it is worthwhile checking both as whoever did the bearings must have been oblivious to the adjustments that could result from changing the hub relationship to the suspension strut
  4. Re: Front wheel bearing replaced - what have they got wrong?
    Thanks for the replies. It sounds like they made a complete balls-up of the job.
    One more question - if they have altered the camber is this dangerous or is it safe to drive the car for a few days until I can get it sorted out? I presume specialist tools are needed to check the camber.
    Chris Melluish
  1. Front Wheel Bearing - Bit of dirt
    By Clinterous in forum Chat - Anything with wheels
    Last Post: 07-05-2009, 11:37 PM
  2. Mk3 Golf - Front Wheel Bearing Hub Torque Settings
    By BugBit in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2008, 01:32 PM
  3. a4 quattro front wheel bearing
    By sbt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-10-2007, 05:05 PM
  4. Wheel bearing???
    By HMIT in forum Golf MK4 - 1999 - 2004
    Last Post: 03-09-2007, 06:06 PM
  5. Front Wheel Bearing replacement
    By tornadored7 in forum Archive posts
    Last Post: 30-08-2007, 09:05 PM
