Thread: in1 or inI message
Results 1 to 10 of 10
  1. in1 or inI message
    Mar 2008
    just got this car cheap
    anyway fixed the central locking pump thanks guys for the write up
    but have this on the speedo as i turn key stays on for like 30 sec then goes back to speedo
    what does it mean do not have the manual
    so any help would be great
    now if it is the service light how do i turn off
    thanks
  2. Re: in1 or inI message
    Resetting SID with the adjuster buttons for trip recorder and clock
    – Switch off ignition.
    – Press the reset button for the trip recorder on the dash panel insert and at the same time switch on the ignition.
    The display of trip recorder shows: “serviceOIL”.
    – Release the button.
    – Pull out clock adjuster knob in dash panel insert for approx. 2 seconds to reset “serviceOIL”.
    Depending on manufacturer of dash panel insert the trip recorder display will either continue to show “serviceOIL” (Nippon Seiki) or it will display “- - -” (VDO).
    – Press the reset button for the trip recorder again to call up the next type of service.
    The display of trip recorder shows: “serviceINSP”.
    – Pull out clock adjuster knob -1- in dash panel insert for approx. 2 seconds to reset “serviceINSP”.
  3. Wink Re: in1 or inI message
    Crawley
    hi. i have the same problem but the display says "In 2". According to the manual "In 1" means inspection service and "In 2" means additional servicing work. I was thinking of taking the car into service to see what's wrong before resetting it
    btw can it be reset using the same steps kenney? is there a way to make that disappear under normal conditions? i mean without a reset procedure. if you reset it does it mean that it will never appear again?
    thanx alot.
    cheers
    '98 A4 1.8SE 235k miles..... and going
    '97 A4 1.8T 148k miles...... gone
  4. Re: in1 or inI message
    Hi You can follow the same procedure.Yes it will reappear when the car is due for a new service either time or distance which ever the instument is addapted for.
  5. Re: in1 or inI message
    May 2007
    on earlier cars, you can only reset inspections via PC, on later ones you can use routine listed above
  6. Re: in1 or inI message
    Oct 2006
    just tried this & it doesn't work for mine......
  7. Re: in1 or inI message
    Crawley
    same here... doesn't work
    kenney...
    can you plz write one more time the procedure but in a more detailed way... like what does "switch on the ignition" mean?
    does it mean that i start the engine or just turn the key until all the indicator lights on the display turn on?
    sorry for the silly qs
  8. Re: in1 or inI message
    Hi The above procedure is from late 1997 models and newer,earlier models you need diagnostic equipment,to reset the service interval
  9. Re: in1 or inI message
    Mar 2008
    well since the above does not work for me
    i have a vag-com working on my car
    but it is in demo mode can this reset the service or int code
    thanks
  10. Re: in1 or inI message
    Oct 2006
    Quote Originally Posted by kenney View Post
    Cheers for that - how much is the re-set tool - be handy to have one.............bloody annoying me now
  1. Dash Message
    By ant130979 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2009, 04:14 PM
  2. me first nope second message
    By naush187 in forum New Member Introductions
    Last Post: 19-01-2008, 03:29 PM
  3. odd message ?
    By y-dog-bike in forum Archive posts
    Last Post: 24-11-2007, 03:40 PM
  4. Error message
    By A6_JAck in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-09-2007, 01:35 PM
  5. Oil sensor message
    By jms in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-07-2007, 04:55 PM
