Thread: cooling fans
  1. cooling fans
    dazzer Guest
    well,ive had my cooling fans looked at because they come on as soon as i switch the engine on.its my climate control something to do with that or it might be the temperature sensor in the radiator .having diagnostics next week and c what it shows up. what do u people think out therewhen the climate is on auto or just on a hot temperature setting,like for winter setting,its on all the time.when its on econ the fans dont come on when i switch on the engine.so weird ha!.thanks everyone for reading this.cheers
  2. Re: cooling fans
    Bath, Somerset
    Sounds normal to me. I keep my climate in Auto mode and the fans run when the engines running. They vary in speed depending on the climate setting and weather. They won't run in Econ mode because you have turned the air conditioning off.
  3. Re: cooling fans
    134 Post(s)
    1995 Post(s)
    If you run on Auto, the fans will come on.
  1. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
  2. Cooling fans
    By dazzer in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2008, 08:38 PM
  3. cooling fans
    By simon74 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-02-2008, 11:55 PM
  4. fans on radiator
    By charles0106 in forum 80 - 90
    Last Post: 07-10-2007, 06:38 PM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    Last Post: 03-01-2007, 03:55 PM
