Thread: passat autobox prob
  1. Exclamation passat autobox prob
    hi i have a2001 passat tdi 130 sport automatic when putting into reverse itwill creep back as normal but as soon as u put your foot down it seems to be slipping out of gear .more so on hills if i try putting it back in park and reverse again sometimes it works do i need gearbox rebiuld or is it easy fix please can someone tell me and a rough cost thanks
  2. Re: passat autobox prob
    my 2000 w-red tdi auto does the same thing and it's not good news. the first sign of the gearbox needing to be rebuilt is the reverse gear as it works on hydraulic pressure. then the forward gears will start to slip while on motorways etc. your looking around £1200 to rebuild. but dont worry, i put 40k on mine and it's still going.
  3. Re: passat autobox prob
    london/ UK
    Quote Originally Posted by tomt 59 View Post
    Do an gearbox oil change + filter(dealer call it strainer) and see if it improves. You will need diagnostic equipment to monitor fluid temperature for the corect oil level. Too much or too litle is bad for the gearbox. If the oil does not smell burnt then one of the valves in the valve body is leaking hence litlle pressure on the reverse clutch so its slipping. A recconditioned valve body is £400...
  4. Re: passat autobox prob
    Aug 2008
    Quote Originally Posted by adamss24 View Post
    Good advice. Gives me hope! I'm sure the same applies to the forward clutch. My Tiptronic surges by a few hundred revs several times a minute, sometimes juddering, part throttle in the lower gears, but this goes away when I put it in manual. £400 sounds a lot more appealing than a complete rebuild.
    It's booked in to a main dealer next week for the diagnostic, but after reading this forum I think it's heading Crashers way regardless..
  1. passat autobox prob
    By tomt 59 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-03-2008, 10:10 PM
  2. audi a6 autobox
    By golf tdi 02 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 14-04-2007, 08:31 AM
  3. Help! Passat Rear central locking Prob!
    By Cian_ie in forum Passat - Archive Topics
    Last Post: 23-03-2007, 12:33 PM
  4. Passat VR5 Starting prob
    By asmiffy in forum Passat - Archive Topics
    Last Post: 22-03-2007, 02:08 PM
  5. autobox
    By rob5150 in forum Touran - Sharan - Caravelle
    Last Post: 07-10-2006, 10:48 AM
