Thread: Engine noise in speakers
  1. Engine noise in speakers
    Mar 2008
    Just uprated the sound system in my golf and im now picking up the revs of the engine in the speakers. like a high pitch noise.
    Somebody mentioned a supressor for the alternator what do you guys think?
  2. Re: Engine noise in speakers
    Mar 2008
    essex
    hello m8 had same prob it depends where ur amp is installed and quailty of cable(speaker)
  3. Re: Engine noise in speakers
    I have had this problem before where the RCA cable is running down the same side of the car as the power cable which goes to the amp. Thats what gave me the noise your describing.
    Hope this helps.
  4. Re: Engine noise in speakers
    7 Post(s)
    The most probable cause would be a bad or non existant earth to the stereo. I'd check that first.
  5. Re: Engine noise in speakers
    Dec 2007
    Inverness
    check the wiring then fit a supressor, my mate had the same in his crappy 1.2 fiat punto, sounded like the engine was whining, just right in your ears tho, nightmare!
    N reg mk3 golf 1598cc
    Rolling stones anniversary trim
    dragon green
    Favourite mod - vanilla magic tree
  6. Re: Engine noise in speakers
    Mar 2008
    wisbech
    Speaker cables should be run down the opposite side of the car to the power cable. this is because the speaker cable will pick up sum of the power from the power cable and cause this whining you can hear.
    hope u sort it.
  1. noise from engine.
    By amphiltis in forum Golf MK3 - 1993 - 1999
    Last Post: 05-09-2013, 07:46 PM
  2. engine noise on '07 A4 2.0TDI (170)
    By JJ1976 in forum Audi A4 - Archive Topics
    Last Post: 27-01-2008, 08:48 PM
  3. 1z engine noise
    By eddiemax28 in forum 80 - 90
    Last Post: 27-01-2008, 02:14 PM
  4. engine noise!
    By grayman in forum Golf MK4 - 1999 - 2004
    Last Post: 22-11-2007, 01:12 PM
  5. Noise from engine - help
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 03:56 PM
