Thread: Dash/Instrument Lights on 1.9 SDI 2002
  1. Dash/Instrument Lights on 1.9 SDI 2002
    Mar 2008
    Hi all,
    The backlights for my dash (the ones that light up (blue) the speedo, clock, rev counter, heating controls and buttons when the headlights are turned on) stopped working recently.
    I've checked the fuses inside the drivers door and the ones next to the battery and all are OK. I'm a little confused as to what the problem could be since if all the lights blew would a fuse not have not gone too? I'm suspecting wiring troubles.
    Any ideas what the cause might be and how i go about trying to sort it out? Is it a case of removing the entire dash and checking the wires? If so I would probably take it to a mechanic, but wanted some advice or input first incase there is anything obvious i am missing.
    thanks
    Rob
  2. Re: Dash/Instrument Lights on 1.9 SDI 2002
    Southampton, Hampshire
    could be bulb related, but from what I understand the dash display is a sealed unit, I don't think you can get to it to replace the bulb(s).
    have a look here https://www.vwaudiforum.co.uk/forum/s...ht=dash+lights
    Rob
    '01 Bora TDi130 Sport
  1. Replies: 38
    Last Post: 08-06-2021, 07:43 AM
  2. Replies: 3
    Last Post: 26-12-2007, 11:36 PM
  3. A3 2.0 Tdi Dash Instrument Cluster
    By sterling1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-10-2007, 11:59 PM
  4. dash instrument panel not lighting up at night
    By charles0106 in forum 80 - 90
    Last Post: 10-09-2007, 06:23 PM
  5. Removing Instrument Cluster On 2002 Golf V5 To Remove Emissions Warning Light Bulb
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-06-2007, 06:02 PM
